Question about InFocus Office Equipment & Supplies
The cables to connect my ELMO to my InFocus DLP X2 projector are not compatible. What adapter do I need?
  • 2,237 Answers
A vga to dvi-d adapter
Posted on Oct 16, 2009
I DON'T HAVE A DATA CABLE
You need a wizard cable. Wizard II or Wizard III.
http://www.ebay.com/itm/InFocus-Cable-Wizard-II-590-0221-04-Projector-Adapter-for-PC-and-MAC-/360784553788
Sep 28, 2013 | InFocus LP435Z DLP Projector
DATA CABLE
InFocus IN2102EP Projector My projector is connected to an Elmo TT-02s digital presenter that I use to show documents to my Students. When I first power on both devices, they seem to be working fine then...
Most projectors have an auto search function which can be switched off. You can then set the source to the specific input that you are using. Of the problem persists it may be the battery of the Elmo. (If it has one) Maybe it isn't strong enough to send the signal and maintain it.
Good luck.
Aug 05, 2011 | InFocus IN2102EP Projector
InFocus IN32 DLP projector.Picture is ok with composite video, but does not sync when the source is VGA. Existing non-functional LT1675, MAX4019 are now bypassed & VGA connections are made to AD9882A...
Were the MAX4019's used as X2 buffers or invertor mode. If they were X2 then your signal level is down by half to the AD9882A. If the LT and MAX devices have failed, then maybe the AD has gone as well. Is the power supply levels to these chips correct. As a test, check if the VGA input selector line to the LT can switch correctly. If not then you are correct. I'm wondering if a local lightning strike in the area has raised the earth potential to everyone house and gone up your vga cable into the unit and taken out these devices.
Jul 06, 2011 | InFocus Work Big IN32 DLP Projector
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
I neen help seting up my infocus sp777 calibration and problems with ps3 and sky hd do you no any one in milton keynes who can help ?
Try setting the output of the PS3 to 720p or 1080i
And if your not using the component video on the 4805 try that. If you are using an HDMI to M1-D adapter make sure it is HDCP compatible. (P&D)
Cheers
Oct 31, 2009 | InFocus ScreenPlay SP777 DLP Projector
Infocus X2 searches won't display desktop
In the projector's menu under "sources" make sure that the box to the right of "Computer" is checked. Also check the box at the bottom of that page that says "auto source select" or something. But it is the last thing on that menu and should be checked.
Cheers
Oct 20, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Sep 01, 2008 | InFocus X1 Multimedia Projector
Infocus x2 dose nothing
Assuming the power outlet and cable is OK the most likely problem is the power supply and needs to be replaced.
Dec 06, 2007 | InFocus X1 Multimedia Projector
123 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
