Question about Hitachi 60EX01B 60" Rear Projection Television
Water stain inside of screen glass
Water was spilled on top of the TV. Some water leaked through the crack where the glass screen cover is connected to the TV. I now have a long black line or streak going from top to bottom inside of the glass. Is there any way to disconnect the glass cover, wipe it clean, and reconnect it to the TV without damaging the whole thing?
I HAVE THE SAME PROBLEM
Posted on Nov 20, 2008
    Genius:
  • 1,153 Answers
Yes, you can check with ctechnicians.com for instructions on disassembling.
Posted on Dec 23, 2007
SOURCE:
I have a kenmore coldspot model 106.53532300 and the water will not dispense from the door the icemaker is working just can't get water from the door...really miss it! Can anyone tell me what to do?!...
Hello Ray;
My name is Peter. I am a retired field service refrigeration technician.
Ok, It may have been the water bottle. But, you have an old unit.
So, lets check it out once more.
1.) After time, from the heat, the plastic tubing for both your water lines to the water dispenser and ice maker will dry rot and crack.
Check: Pull your unit out. Have someone draw a glass of water from the water dispenser, while observing in the back both the water supply valve and the larger plastic tubing going to the water dispenser. Is there a leak when pressurized?
2.) Wait for when your ice maker fills and observe the smaller plastic tubing. Does it leak under pressure.
kenmore-coldspot-model-106-53532300-q5zw2lslmquh13tixvlr3ryr-3-0.jpg Part Number: Substitution: 4387492 Cost: $10.00
3.) Drain Pan - This too will crack over time do to heat. Pull your unit out so you can get behind it. Remove the lower back cover.. There are about 8 screws easily removed. Observe the drain tube from the under body of your refrigerator and the black drain pan where it empties. Observe around the drain pan. Are there and brown or dark stains on the floor? If so, then you have a cracked drain pan.
Repair: Unplug the refrigerator. The compressor and surrounding copper tubing prevent you from replacing the pan. When I was in the field, I would take duct tape and seal the cracked area. Then, I would cover the duct tape and surrounding area with a high temp silicone adhesive.
Mar 19, 2015 | Kenmore Refrigerators
Leaks water from bottom
Is it really from the BOTTOM, or is it spilling out the overflow holes in the back, then running down to the counter? If it's just spilling out the overflow holes, don't put quite so much water into it.
If it's really leaking from the bottom, and it happens even if you put only one or two cups of water into it, then the little hose running from the heating element inside up to the top filter has cracked or come off. You can fix that by opening the bottom of the coffeemaker (UNPLUGGED FROM THE WALL). You'll see where the rubber hose connects to the heating element and runs up along the rear tank. Check the connection where it attaches to the heating element.
Jul 31, 2014 | Gevalia CM-500 12 Cup Coffee Maker
Water spilled inside 25'' Sanyo will not turn on
The water has already done its damage. Try leaving the set unplugged and drying out for a few days then try it again otherwise you will most likely spend more to repair than to replace.
Mar 02, 2010 | Sanyo Televison & Video
I cracked my glass top stove and i would like to know if i should still use it as it still works, if not can i get it fixed?
You can order another glass top for around 2 to 3 hundred dollars.
If water and other spilled liquid can leak through the crack onto the burners under it it will cause them to burn out. That' another 80 dollars or so if the big one goes out.
Post your model number at one of these sites to see what the glass will cost.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
http://www.appliancepartspros.com/partsearch/
http://appliancejunk.com/forums/
Nov 18, 2009 | KitchenAid KESC307 Electric Kitchen Range
Hard water stains on my car's wind screen
Windex and newspaper should do. You sure they are water spots and not the glass? When they set out the plastic impregnated in the glass (safety glass), seperates slightly and looks like a water spot or even a bubble. It is a combination of heat & sun rays. May have to live with it or replace the glass.
May 03, 2009 | 1995 Mercedes-Benz E-Class
I have water on floor on the left of a top loading kenmore washer
There are hjoses on the inside of your machine that connect to the tub. The fill is turned on by a electrically controlled valve. When it opens, the tub fills and if the hose is cracked or the connection is loose, the water will spill out of the hose. You have to open the back up (I think that is how you get in there) and check the hose and the control valve. Does it only leak on the cold? Or does it leak on both?
Mar 01, 2009 | Kenmore 23822 Top Load Washer
Black oval spot on screen when turned on
The LCD screens are built with a over-cover of a plastic film and the LCD is inside the cover. Any damage on the LCD glass will not be felt physically on the outside of the screen. So, chances are your LCD is cracked if you find a spider web or a liquid spill effect visible.
Dec 26, 2008 | Haier Portable DVD Player PDVD7
Water stain on the front of our Akai PT5499 Projection TV
Hmm... should evaporate on its own. The only way to access behind the screen is to take the whole back off the TV, and then inside theres another panel that covers the main reflector and screen. I wouldnt recommend doing that just for water tho.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
Regular spill stain problems
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jun 13, 2007 | Maytag MEC5430 Electric Cooktop
Hitachi 60EX01B 60" Rear Projection Television Logo
350 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
