Question about Campbell Hausfeld 04 Gallon Twin Stack Compressor HL5502
Builds pressure to 50 and won't shut off. Smells hot
    Problem Solver:
  • 8 Answers
REVISA POSIBLES FUGAS EN LA VALVULA CHEK PUEDE TAMBIEN ESTAR ABIERTA
Posted on Oct 06, 2009
I have a 2002 Mitsubishi Diamante the coolant fan will not come on. The gage says it isn't hot but it smells hot. What could be the problem ?
check fuses and relays -engines smells hot [all engines put out heat and smell hot ]could be nothing the engine could be running correctly or test the temperature sensor ,fan motors and fan circuit --if smells hot because of leak look for leak have coolant system pressure tested
Oct 15, 2016 | Mitsubishi Cars & Trucks
No hot water comes into the house
1) Copy following link:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#no
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
2) One pipe on top of heater is warm??? >> breaker is ON >>> this indicates that electric water heater has hot water.
When you opened the TP valve, did hot water come out???
3) Feb 2013 >> add a comment.
Feb 24, 2013 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a flotec 1 hp pump. Wife washed 3 loads of clothes in a row and noticed we run out of water a while later. I shut pump off and noticed pressure tank low on air. I put 18 lb. air in tank and...
If in the past your system can build-up pressure up to 40 psi even if the supply valve is open and water is being used in your house, then your pump impeller maybe already worn out that's why its pumping capacity was reduced.
Nov 12, 2012 | Flotec Corrosion Resistant Shallow Well...
I have a porter cable compressor, but the pump won't shut off, and the pressure won't build it
Hi
Here are a few things to check, you may have already checked some of these.
*Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
*Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
*Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
*Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
*Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
If correct then it will **** you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
*Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
*Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Please take time to rate me
Bud
Nov 01, 2012 | Porter Cable Air Tools & Compressors
My bostich 6 gallon pancake compressor won't shut off. It get so hot it stinks and I turn it off. The pressure gauges show that it should.
You didn't state your model number so I won't be able to tell you what specific parts you may need. If your guages are correct and the tank is coming up to pressure as it should but the motor doesn't shut off when the peak pressure is reached, you have a bad pressure regulator. They're easy to replace. If it's possible your guages are off and the shut-off pressure isn't being reached, the motor will continue to run as long as it has power. Reasons for not reaching peak pressure in the tank could be a leak somewhere like the pump to tank line or drain valve, a bad valve plate that isn't sealing properly or damaged piston or cylinder assembly.
Aug 16, 2012 | Air Tools & Compressors
My MAC 700 laboured to kick in to build pressure, and then finally quit. It won't turn on with the switch in the
All compressors dump a little air when they shut off, it's the air in the pump head and discharge tube. This bleed off should only last two to three seconds. If this pressure isn't bled off the motor won't be able to restart when the pressure drops in the tank becuase there will be too much pressure in the pump head for it to start turning again. If you have a longer bleed off or if the motor is struggling to restart most likely you have a stuck or broke check valve. It's the piece where the discharge tube connects to the tank. It's designed to let air into the tank but not back out so the pressure valve can bleed off the air in the pump. On rare occasions you can remove it and clean it out but usually they have to be replaced. You would need Makita Part Number 409004-E.
Feb 29, 2012 | Makita MAC700 2 HP Air Compressor "The Hot...
Can't get both hot water running at the same time. Delta Shower faucet
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
May 23, 2011 | Delta & Single Handle Shower Faucet
My PRO-SOURCE air compressor will not go over 50 psi
Your compressor has got a 'ring' problem. The rings on the pistons that compress air are leaking air by them and need to be replaced. Unless it's the 'pressure release' leaking. When it gets to 40 PSI or so, unplug it and listen for a leak. If no leak then it's the rings. inside on the piston. If you adjust the pressure switch all the way low, it might shut off near where it builds pressure to and you could at least use it some.
Sep 26, 2009 | Air Tools & Compressors
I have two hot water tanks in an 11 unit building One side of the building has water coming out of the hot water spigots and the other side of the building has no water coming out of the hot spigots. There...
Duissamble the faucet after turning off the shutoff vavev and look for an obstruction. The only shutoff if the tempature gets too high is the pressure/tempature pop off valve which would redrirect the discharge down another path. Go to the waterheater and see if it is coming out from another open pipe from the heater.
Jan 17, 2009 | Water Heaters
Smells hot what do I need to check?
Check your vent to the outside to make sure it is clear of obstructions, lint build up, water retention due to a sagging vent, etc.
Apr 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Campbell Hausfeld 04 Gallon  Twin Stack Compressor HL5502 Logo
89 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
