Question about Honeywell Programmable Thermostat Heater
Honeywell cm61 controller
Don't know how to operaye a honywell cm61 temperature controller
  • Andy Priest Mar 18, 2008
    I have a problem with my honeywell cm61 controller when in auto mode I have set 4 on off times and left the remaining two blank. During the night and early afternoon the controller overrides this and reverts to a default temperature. This brings on the boiler when i do not want it to come on. When looking at the display when this happens there is a small 'opt' written on the display as well as the auto. Any help would be appreciated. Thanks Andy
  • 3 Answers
Turn off ‘Optimum Start’
Step 1 Put the thermostat in the OFF position.
Step 2 Press 3 buttons together (at the same time) which are the INFORMATION BUTTON (i) and PROGRAM BUTTONS 3 & 4.
This will show a code of ICL 1 – now let go of the buttons.
Step 3 Press PROGRAM BUTTON 2.
This will now show a code of 30t 1
Step 4 Press the + BUTTON (on the left of the display), tap through until you reach 15 OP 1
Step 5 With the TEMPERATURE DOWN BUTTON; change the 01 to a FLASHING 0. Confirm the FLASHING 0 with the INFORMATION BUTTON ( i ). The 0 will now be static.
Step 6 Put the Thermostat back in the ‘AUTO’ position.
‘OPTIMUM START’ is now switched off.
Posted on Feb 12, 2009
  • 98 Answers
Found this info for you, hope it helps.
http://www.honeywell.be/DocsAdobePDF/EN/Chronotherm/CM61_pd.pdf
Just click the link or copy/paste it into your browser.
Posted on Dec 23, 2007
Check out moneysavingexpert website as there is a posting from Honeywell about turning off the 'Optimum Start'. Have doen this to mine which had same problem so fingers crossed that it works.
Posted on Jan 22, 2009
I had the same problem and the fact is the system is trying to predict how long it is going to take to get to the temperature at the time required. From the PDF in the previous posting you need to set the Optimisation parameter.
Posted on Nov 24, 2008
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
Cant take off cover to replace battery from my honywell thermostat
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Nov 26, 2010 | Honeywell Programmable Thermostat Heater
My wireless control is not working my heating is there a reset button for honeywell cm61?
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
heatman101
Oct 12, 2010 | Heating & Cooling
I'm trying to wire my honeywell t8011 thermostat Replacing an old Honywell unit.
I hired someone................... Could you please refund my $? Thanks, Danny
Nov 30, 2008 | Honeywell Heating & Cooling
Red LED on honeywell r6660d
The problem is that the 2 units are "not speaking to each other". this could be caused by low batteries or a loss in signal caused by a powercut or an objection in the way of the 2 units.
first you need to turn the power off to the r666od (or otherwise known as the HC60NG) for 10 secs, then turn back on. then hold the grey button in for 15 secs. release then hold in for a further 5 secs.
go to the honeywell cm61 press the off button. hold temp up. temp down and prog 1 in for 3 secs until the dipslay goes to INST. at this point release all 3 buttons then press the i button until a beacon starts flashing.
this is now the end to your problem.
N.B the reason the green light was on is because the man override button will have been pressed.
hope this helps
Nov 14, 2008 | Honeywell Programmable Thermostat Heater
Radiators cold when thermo says otherwise !
First, check to see if the battery in the stat is good. If you can move the manual temp up and down...causing the relay to click on and off, the unit ought to work. If not the battery is bad or the stat is. IF THE UNIT IS ON 110V, you can't do the following:
If this is a two wire connection, simply short them out. If the heat comes on, the stat is bad. If not, the relay package is likely defective. You may want to get help from someone who knows electrical items.
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
What temperature should be set on a honywell 4 cycle thermost during the summer months
To gain the most efficiency, please visit your local energy companies web site. They will list the best temperatures for your region to save the most amount of money. The EPA has some good information regarding this issue as well.
Jul 03, 2008 | Honeywell Heating & Cooling
My heat is turning on but the fan isnt working. my honeywell thermostat is showing a flame and a blinking battery, and i know nothing about this thermostat, we just moved in . Can u help?
This is not a PC problem
Symptom
Heating comes on, but sometimes it
gets too hot, sometimes too cold.
Neutral not connected
Cure
Check wiring in room thermostat. Look for a
connection to the Neutral terminal (N 2 on
the Honeywell T6060, T6160, and T6360).
Make sure that it is connected (check
continuity).
If there is no neutral available, replace with a
two-wire thermostat, e.g., CT200, CM61 or
CM67. These will also offer extra energy
savings, (Without a neutral connection, the anticipator within the room thermostat does not work,
so the temperature control reduces from ± ½ºC to ±3ºC. People can feel a six degree
temperature swing. Then, if they try to adjust the room thermostat to overcome the
problem, the temperature swings become even worse.)
Mar 16, 2008 | Computers & Internet
Central heating thermostat
Looks like it was replaced by the CM67 series, try this link for the manual:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
Geno
Feb 29, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
2,769 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
