Question about Nintendo Wii Console
Movement my Wii remotes only work for the A and B buttons and the point and move feature. The controller does work for motion games, like bowling. I bought a new controller and a new sensor bar and still no luck. It worked one day and the next it didn't. Any suggestions would be appreciated.
  • 1 more comment
  • Anonymous Dec 24, 2007
    i have the same problem with mine...HELP
  • Anonymous Dec 26, 2007
    the movement does not work for baseball or nothing like that
  • Herb3 Dec 29, 2007
    Of course, I would do that if I had the receipt. It was a gift and I never received the receipt. Not sure where it was purchased and unable to contact the person who bought it. Any other, non-obvious solutions would be appreciated.
  • 46 Answers
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Posted on Dec 25, 2007
I have tried syncing the wii remote and it still wont work...little blue lights just flash and then nothing. What do i do?
Did you hold both buttons for a few seconds?Also when you sync the remote,you need to point it at the motion sensor bar.Hope that helps.Good luck and game on!
Jul 08, 2010 | Nintendo Wii Remote Controller
Wii remote not sensing
ahh. First im going to go threw the obvious:
1) Make sure that you see that little blue light on the WiiMote.
2) If you don't, try to sync it to your Wii.Press the red button under the little door on the front of you wii, at the same time press the button on the back of the wiimote.
3) make sure there are good battery's in it.
If that doesn't work go to this link: http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Feb 16, 2010 | Nintendo Wii Remote Controller
Motion on wii doesn't work
Sometimes, hitting the remote of all sides, kind of hard can solve the problems, if not i suggest seeing your local Electronics/gaming Store !
Mar 19, 2009 | Nintendo Wii Console
Wii remote turns off
It sounds like you either have a low battery, or your motions may be dislodging the batteries on your controller. When the controller is off and you press a button, check to see how many of the four blue lights on the bottom of the controller are flashing. This tells you how much battery power you have: four lights is full, one light is low. If it's saying your battery is full, try taking the battery or batteries out and putting it back in. Good luck!
Jan 08, 2009 | Nintendo Wii Console
Unable to bowl or throw with the remote
It's possible your tilt sensors are stuck in the controller. Turn the controller upside down (buttons down) and slap it against the palm of your hand. This is the easiest way to unstick those springs. Good luck!
Jan 07, 2009 | Nintendo Wii Console
Wii doesn't work
Hey mushbean,
If the motion sensor in your Wii remote is not functioning properly, Nintendo has recommended that you try the following:
1) Hold the Wii remote with the button side down.
2) Gently tap the button side of the remote against the palm of your other hand a few times.
3) Check the remote to see if it properly responds to motion.
Should this not solve the problem, you may want to check out the online FAQ and troubleshooting guide developed by Nintendo for all Wii remote issues. The FAQ can be found through the following website:
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 25, 2008 | Nintendo Wii Console
My wii remote
@ Slivic22
Some games does not use Sensor Bar pointing because they play with motion/accelerometer only. After you select the number of sets on Wii Sports Tennis, there is no Sensor Bar pointing except for Pause menu. That's because you Swing the remote like a racket.
May 24, 2008 | Nintendo Wii Console
Wii freezing up
Hi Ashley,
It sounds like the accelerometer in your Wii Remote is not working properly.
The "point-and-click" stuff like the Wii Menu use the WIi Remote's camera (which is behind the dark part on the front of the Wii Remote). The motion-sensing for swinging, tilting and other motion uses the accelerometer in the Wii Remote.
Wrap your Wii Remote in a towel and give it a whack against your knee (not so hard as to injure your knee) - sometimes the accelerometer part gets "stuck" and needs to be jarred out of position.
If that still doesn't work, then go to Nintendo.com, click Support, and go to the Wii Troubleshooting section for more options.
Also, you don't have to use the same remote as #1. The first remote that is activated will become #1.
You can also push the Home button on the Wii Remote, then point to the bottom (where the battery levels are shown), press A, then click on Reconnect. It will tell you to press the 1 and 2 buttons on each remote in the order you want them to appear. Press the 1 and 2 buttons on the remote you want to be #1, wait for the remote to sync (the Wii will make a happy nosie), then do the same for the remote you want to be #2, etc.
Apr 01, 2008 | Nintendo Wii Console
Wii remote controller not fully funtional
in baseball you have to hold it beside your head and in bowling you have to raise your WII control up and realese th B button(hold B button than do instruction)(not for the Baseball game)
Jan 02, 2008 | Nintendo Wii Console
Wii Remote Problem
try syncing the remote (under the cover on the back of the wii remote where the battery's are there is a circular red button press it then on the front of the wii where you can put your SD card there is a rectangular button press it if that does not work then try doing it the other way around if that does not work keep trying if that does not work i dont know what will
Oct 15, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
53 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
