Question about Konica Minolta DiMAGE Z10 Digital Camera
Viewfinder is off. Is there a button to push to get the viewfinder to work again.
Viewfinder is dark until picture is taken.
Have you tried pressing the display button ? It should switch from LCD to viewfinder.
Jan 26, 2013 | Canon PowerShot G2 Digital Camera
My camera is locked. The viewfinder doesn't show an image and there is no button to press that will take a picture. There is a large yellow dot to the right of viewfinder and when tap it it enlarges...
Either restart your iPhone, or reboot the programme. It happens a bit with the 4S, but even more so with older iPhones.
To reboot the programme on the 4S, this is what I do:
1. Double-press the round home button. This will bring up a row of apps on the bottom of the screen. These are the apps that are currently running.
2. Swipe until you get to the Hipstamatic app.
3. Push down on the Hipstamatic app and hold until it jiggles and a red minus sign comes up.
4. Tap the red minus sign and your iPhone will shut the app down.
5. Press the round home button again - twice.
6. Now tap on the hipstamatic icon to open it again - it should now be fine.
Jun 14, 2011 | Synthetic Corp Hipstamatic
Viewfinder is blank, but the camera works normally.
Iris or Aperture not working its all time off so that you can not see through camera.You need to change Iris cable.
Mar 31, 2010 | Canon PowerShot SD430 / Digital IXUS...
CANON POWERSHOT A640 LCD VIEWFINDER STOPPED WORKING
nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Oct 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Viewfinder screen and viewfinder are black and lens is off
Make sure the selector switch is turned to record (the center position) and camcorder is turned on. Make sure the viewfinder is pulled out fully when you look in it. If that doesn't work try resetting the camcorder. Open the LCD and there is a small hole near the play button, gently push a paper clip in the hole all the way and press the power on button.
Mar 24, 2008 | Sony Handycam DCR-DVD101 DVD Camcorder
Panasonic VS5 MOVIE CAMERA
1. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS AND CREDIT TO LABBER
Feb 16, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
JVC camcorder with blurred images
It could be an issue with the dioptre adjustment: 1 Set the Power Switch to ?A? or ?M? while pressing down the Lock Button located on the switch. 2 Make sure the LCD monitor is closed and locked. Pull out the viewfinder fully and adjust it manually for best viewability. So slide the rubber eyecup toward you. 3 Turn the Dioptre Adjustment Control until the indications in the viewfinder are clearly focused. The control is a litttle knob on the sied of eye-piece. While looking through the viewfinder, turn the knob until it is focused. Hope this helps. NewMediaMan
Jun 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Konica Minolta DiMAGE Z10 Digital Camera Logo
21 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
