Question about Casio Exilim EX-S600 Digital Camera
With full battery, lens only comes out a bit - just clicks.
Thought I'd had an answer, but Casio wasn't on the list. The lens cover opens about half way and the rest just clicks. Help!
3 Suggested Answers
SOURCE: casio camera lens stuck
i droped my camra and now the lense is like stuck where can i go to get it fixed
Posted on Jul 27, 2008
  • 11967 Answers
SOURCE: my casio exilm lens keeps jamming. The lens cover
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 10, 2010
Hi I just found an old Casio Digital Diary SF8300. I changed the batteries because it wasn't coming on! But now i realise that even with brand new batteries it doesn't come on! Any help would be...
There should be a hole somewhere on the device that you can stick a paper clip into. If you do this and hold it for 10-20 seconds it should reset the device. If you reset it and it still doesn't power on, even with new batteries....chances are that you have a hardware problem that would need to be fixed by the manufacturer.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 06, 2011 | Casio Boss Business Organizer
Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
Mar 22, 2010 | Casio Watches
My lens is stuck!
Sometimes this can happen if the battery cover was accidentally opened while the lens was moving. Try something simple. Turn the camera off. Open the battery cover and remove the batteries for 5 minutes. replace the batteries and secure the cover. Turn on the camera. The lens should go to it's home position. Let me know if this helps. And thanks for coming to FixYa. Don't forget to rate my answer!
Rob
Feb 08, 2009 | Polaroid T831 Digital Camera
Camera really messed up!
Have you tried taking out the batteries and leaving it alone for a bit, then loading new batteries? I would try this first before anything. Good Luck.
Apr 09, 2008 | Casio Exilim EXZ75 Digital Camera
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
Lens only comes half way out
I had a problem that may be related to yours. From time to time, whenever I opened the cover, the lens wouldn't work properly. It would make a grinding noise and then when I took pictures they would all come out out of focus. After much fiddling about, I eventually discovered that if I set ALL RESET to FALSE on the SETUP menu, it returned to normal. Possibly this could fix your problem. Otherwise maybe its a battery problem. My camera sometimes refuses to take pictures when the battery is low.
Sep 24, 2007 | Olympus Camedia C-350 Digital Camera
Casio exilim ex-24u
more than likely you will have to send it in. I don't think there is anything that you can do to fix that at home. If the pics still come out ok you can live with it. If pics get blurry then you will have to send it in.
Apr 08, 2007 | Casio Exilim EX-Z4U Digital Camera
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
12 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
