Our water heater was shutting off after about a minute of use. I called the Rheem support number and they told me:
1. They wouldn't support me because I used flexible pipe for the gas line -- it had to be black pipe. The fact that the manual said flexible pipe was OK for lengths under 36 inches was irrelevant to them.
2. The error code represented some sort of blockage or gas flow problem. They sent me a 10-page PDF file detailing the steps necessary to take apart the unit, remove the burner, and clean everything.
After spending about four hours disassembling the unit I came across the ODS (Oxygen Depletion Sensor) and found a cocoon of some sort inside. Some critter had crawled up there and made a nest inside the 3/8" pipe, preventing the system from properly detecting oxygen levels and causing it to shut down.
I scraped the cocoon out with a small tool, then ran a ribbon of steel wool through the pipe to clean it thorougly. After reassembly everything worked perfectly, and now we get hot water even faster than ever!
The increased performance me think that the cocoon may have been in there before we even purchased it, but might have shifted or worked loose and finally caused an error.
Our Rinai makes a loud noise when heating water. It seems to be related to how much and how hot the...
(More)
Our Rinai makes a loud noise when heating water. It seems to be related to how much and how hot the water demand. It sounds a bit like a small engine under a load
i have a 241 system boiler only doing the heating, it fires up on full for about 30 seconds then...
(More)
i have a 241 system boiler only doing the heating, it fires up on full for about 30 seconds then slows down it plods on for about a 60 seconds then turns off it will then switch on and repeat the above the radiators never get above aired,i have recently fitted a new pump ,any ideas ?
I have a Johnson & starley 25-30 mod airflow 2.It fires up for 20 sec then just gos back to...
(More)
I have a Johnson & starley 25-30 mod airflow 2.It fires up for 20 sec then just gos back to pilot. Ive changed the limit stat, fan, and room thermostat, as anyone got anymore pointers for me please. thanks
Code C2 and 11 comes on when hot water is turned on...have to turn off and on multiple time before...
(More)
Code C2 and 11 comes on when hot water is turned on...have to turn off and on multiple time before the unit will start and run ... very Frustrating... especially in morning. This unit was bought and instlled in Novermner of 2008...
I keep getting an error of C2 11 on my Remote Thermostat for the water heater. All of my gas valves...
(More)
I keep getting an error of C2 11 on my Remote Thermostat for the water heater. All of my gas valves are fully open. The water heater runs for a few seconds then kicks off and the error code comes up
