Question about Sewing Machines
White model 9951 cannot get a stitch to be made, bobbin in right, threaded correctly, but dont know what the settings are for this machine, do not have the book.....i can roll the needle to pick up the bobbin thread but when i go to sew no stitches...who makes this and where can i get a free manual
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
bargainbox
  • 1388 Answers
SOURCE: Bobbin thread issue on new machine
Have you got the stitch width selector on zero ? If not, it may be wanting to sew a small zig zag........if that is OK, ....
Make up some samples of the problems, call the dealer and arrange to take it back to show them the results and either have it adjusted, or show you what needs to be set where to achieve the results you need...........it is under warantee, and you should expect it to function correctly.
I would not advise you fiddle with anything other than tensions and stitch selector on such a new machine.
Ask if you can have a 15min familiarisation lesson on the machine........we actually offer 3 x 30min free lessons on the use of a new machine so our customers can get the maximum benefit from their purchase.
It has proven to be a good business decision, as we get fewer frustrated phone calls and folks actually go and use the machines properly from day one.
www.bargainbox.com.au
Posted on May 31, 2008
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
sew dutch
  • 24 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
Model 4075 white sewing machine thread from bobbin builds up and stops sewing.
Check the stitching and confirm that it is in fact bobbin thread and not the top thread that is creating knots & loops under the fabric. This is usually the case and is called thread nests or bird nests. (You can search the internet for more information about this symptom.)
Install a brand new needle.
Remove the thread from the machine.
ALWAYS RAISE the presser foot while rethreading the upper thread.
Confirm the thread path is correct.
Verify the bobbin is installed facing the correct direction in the bobbin case and the bobbin case is threaded properly.
Set the upper tension to the midway point (factory standard) although it may need to be tweaked as machines change with use and time.
Pull up the bobbin thread. This method works with general sewing projects, not just quilting.
How and Why to Bring up the Bobbin Thread
Begin to test sew slowly.
If the thread is still making a mess, then the machine most likely has a timing issue. There are multiple web sites and videos that discuss sewing machine timing. Or take it for service.
Sep 30, 2016 | White Sewing Sewing Machines
Looped threads
Hello Rosemary
Looped thread on the underside are created by the upper thread. Loops on the top of the fabric are created by the bobbin thread. Whichever one is looping, has very little tension. This may be corrected by:
1. Re-threading the upper thread according to manufacturer's specifications.
2. Re-wind bobbin and re-set it into bobbin case and bobbin case area according to manufacturer's specifications.
3. Ensure that the needle is correctly installed and is the correct needle for the sewing machine.
4. Ensure that he bobbin being used is the correct one for the machine.
5. Double check that the tension on the upper thread is at the correct setting.
6. Double check that the tension unit is clean and free of dust, lint or lodged thread/s.
7. Double check that the bobbin tension is correctly set ... if you are comfortable doing so, otherwise leave it for a qualified technician
8. Make sure that he presser foot is down when stitching.
Please let me know how you go.
Happy stitching.
Nov 14, 2014 | Sewing Machines
Will not stitch
Is the machine plugged in?
Is the bobbin winder on?
Is there a new needle in the machine, right way around and fully up in the needle clamp?
Will the needle thread pick up the bobbin thread?
Will the feed dogs advance paper or fabric?
Is it set for a particular stitch?
Is the machine correctly threaded?
Is the machine correctly lubricated?
Dec 29, 2013 | White Sewing 1888 Mechanical Sewing...
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Mar 06, 2017 | Brother CE8080PRW Limited Edition Project...
CANT GET TENSION SET AND ITS SO FAR OFF DONT KNOW WHERE TO START....vogue stitch old..model.label on back says model 1300/1500 or mercury model 704
try www.sewusa.com repairs page for troubleshooting help. start by cleaning and oiling machine. then wind a new bobbin and put in a new needle. load bobbin into bobbin case and ensure thread goes into tension spring. now dangle bobbin case by holding thread tail, bobbin should hang in the air but release thread if you pull it. adjust the tension screw on case 1/4turns only and test again until you get it tight enough to 'dangle'. now load bobbin into rotary hook of machine and thread top. now test sew and adjust top tension in small increments if neede to balance the stitch. but if top tension is wirking okay then 4-6 range should be fine.
Aug 24, 2011 | Sewing Machines
White sewing machine 2037 I have been having trouble for some time with the bobbin thread becoming snarled. Finally took it apart and cleaned it, which helped. When I sat down to sew a blanket tonight,...
Hello. What you have described presents a large number of possibilities. What I can tell you is this; A sewing machine that uses a bobbin is known as a lock stitch sewing machine. On a basic lock stitch machine, two threads are used to make the stitch - the needle thread and the bobbin thread. In order for the stitch to be made, the bobbin and it's thread are passed through a loop in the needle thread, or more accurately, the needle thread must pass a loop around the bobbin and it's thread, after which the loop is pulled back in and up, taking the bobbin thread with it right up to the underside of the fabric and securely holding it there and the process is repeated, many times over in the blink of an eye. The bobbin, weather placed in a case first or or set directly into, has a place in the center of a rotating hook, which can be oriented in either a vertical or horizontal position. It is the sharp, pointy hook that grabs the needle thread above the eye of the needle and loops the needle thread around the bobbin and it's thread. In less than one full rotation of the hook the needle thread is picked up, looped around the bobbin, and pulled back off of the hook, taking with it the bobbin thread and pulling it up tight to the bottom of the fabric. The process is then repeated, many times over in the blink of an eye. For a sewing machine to function correctly, every aspect of the process must be right, and if any part of the process is not spot-on, failure occurs. Process failure ranges in severity from one stitch out of a thousand skipped to catastrophic breakage of the machine and it's parts. I'm sorry I don't know of a White repair shop in your area. I am new to FixYa, so I'm not sure if it is appropriate to offer my services, but I think it is okay to give you my number if you want to call me. It is 574-808-9613.
Aug 18, 2011 | White Sewing 2037 Mechanical Sewing...
I bought Brother sewing machine Model XL 2230, And could not get a good stitch. Keeps giving me loop either on top stitch or down stitch. Dont know if the single needle can't do straight sewing and dont...
The foot is on the side. Make sure it is clean. Take off the plate and remove the bobbin cleaning all the lint and thread out with q-tips. Oil if needed. Make sure you are using the same thread in the bobbin as on top. Rethread the machine making sure you do it correctly. Change needles using Schmetz as it is shorter and I have found Singer and white label needles are too long and cause problems and well as break easily as they hit the bobbin and cause looping. Not sure what you need to know about the foot. It should have a handle on it so you can put it up or down. Google Brother model XL 2230 and download a manual to find lots of info about your machine.
May 02, 2011 | Brother Sewing Machines
Model 7467. bought in april and it was working. now top and bottom threads will not form "stich". it is threaded correctly! took off face plate - nothing jamming up. machine made a clunking noise...
try changing the needle
check the top thread tension
check to make sure the bobbin is inserted in the bobbin case correctly
check to make sure the bobbin case is correctly inserted into machine
Sep 30, 2010 | Singer Confidence 7467 Mechanical Sewing...
Reassemble bobbin and thread parts because now clumps up stitches multiple on bottom and only a couple on top. can't find my manual for my white 658-31495 machine please help pretty sure it boils down...
you have to try to play with it. take a piece of material and try setting up the correct stitch. It may be old threat too. did you check to see how it was threaded in the bobbin pin. it must be clean.
Aug 04, 2010 | White Sewing Sewing Machines
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
123 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
