Question about Cambridge Audio Azur 540A Amplifier
Intermittent fault on right channel. Sound breaks up/crackles, usually soon after switching on. Then it goes back to normal
  • Cambridge Audio Master
  • 5,487 Answers
Get hold of a Servisol freezer spray, from either Maplin or Radio Shack, depending where you live. Take the top off and look inside. Locate the output transitors for the right channel and with it powered up wait for the fault to go away. Then with the spray, squirt any of the transistors you suspect. If it starts up (the fault) after the spray, that part has gone!
Do them one at a time and wait a while before spraying the next part. If you find one that acts up, to make certain, warm it back up by touching it with a soldering iron. Then freeze again.
Posted on Oct 07, 2009
Preamp intermittent channel
Getting the connections right is a problem. One thing I find helps is the THX DVD discs that certain movies have on them. They have a sound set up to get it right. It makes a tone for each channel so you can hear which channel is working. It should help you set up the system right and determine if any channel has a fault on it.
Feb 08, 2014 | Adcom GTP-870HD 7.1-Channel Amplifier
Vox ac30cc2x fault finding
Check valve you replaced has made proper contact in socket. Plug it in and out a few times to clean pins. Is inteference/crackling noise there when volume is turned down to minimum. This should tell you whether the problem lies before or after the volume control. A good clean can solve many faults. Servisol on pots works wonders.
Ian
Jul 24, 2012 | Radio Communications
I get static and crackling sound out of right speaker, then it blows the speaker fuse, Sanaui au-999 what is wrong
Any of the transistors in the right channel power amp section circuit will have the fault. Check it. A very skilled work indeed.
Apr 15, 2012 | Audio Players & Recorders
Sound comes and goes on the drive channel, and there is a strange crackling on the clean channel. i dont know if its the tubes, the speaker, or electronics.
Using a common lead pencil, gently tap on the smaller tubes in the unit, listening for noises and crackling to change and the drive channel changes.
It is normal to get a slight twang when doing this from the microphonics of the tubes, however, the crackling and up and down volume points to a bad tube.
Sep 03, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Hi, I have a second hand NAD 3240PE amplifier, the right channel has an intermitent crackle but the left channel is fine, Any ideas as to what might be causing this problem?
Crackling is usually a dirty control. Try using an electronics cleaner (with lubricant) and spray out all of the controls and switches. With the unit off, work the controls and switches back and forth to "spread" the lubricant. I would spray, work and spray again.
Update this with the results and also see if the crackling is related to the overall volume level. If tied to the volume level, there could be a transistor inside that is breaking down and causing distortion.
Dan
Dec 28, 2009 | NAD Audio Players & Recorders
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
Picture snaps off, Sound still come through.
A crackling sound could mean that the flyback's insulation has failed and it is arcing inside. If that is the case then it may stop working entirely pretty soon. Take it to a tech as soon as you can, the flyback is a pretty expensive part, however if it blows it can break the set to the point that repairs will not be worth it.
Jun 20, 2009 | Mitsubishi WS-65413 65" Rear Projection...
ILO sound quality
Had a similar issue and turns out I had accidentally switched my language pref to SAP rather than English. As soon as I changed it back, everything was fine...
Aug 10, 2008 | iLO 3200 32 in. LCD Television
Sony TA-540E TWIN DRIVE AMPLIFIER
Hi Jimbob. Sounds like you have dirty/dry controls/switches. The contact lubricant dries out on them producing intermittent and scratchiness when you operate them. Clean any offending controls or signal switches with CRC2-26 by squirting(to flood then internals) each control/switch. you will have to do this from the inside of the amp. You may also have a dirty speaker protection relay, sound may return to a dead channel when you turn the vol up points to that. Good Luck. If you need more info feel free to get back to me here. Happy to talk you through more if you cant sort it out.
regards
Graeme
Mar 22, 2008 | Sony TA-FE370 2-Channel Amplifier
Cambridge Audio Azur 540A Amplifier Logo
416 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
