Question about Praktica DC42 Digital Camera
Every picture is not focussed
Viewfinder screen is blurd but welcome screen ok
No view from screen or viewfinder
Hi, have you tried another memory card in case the other one is faulty ,if the original card is ok then you will have to put into a fuji repairer to inspect. If you are still under guarantee the contact fujifilm.
Dec 17, 2015 | Fuji FinePix S5700 Digital Camera
If you're using the screen to set up your shots, the viewfinder is disabled, and vise versa. It only works one way at a time. MY Question is, where do I actually go to disable the LCD or the viewfinder?
Set the shooting mode to a Creative Zone mode. Under the Settings tab select [Live View function settings] and press OK. Select [Live View Shoot] and press OK. Select Enable to use the LCD or Disable to use the viewfinder.
For full details, please see the "Live View Shooting" section in the manual.
Oct 06, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Black screen on my s6500 fd
I assume you removed the lens cap...;-)
If both the viewfinder and the screen is black, it is most likely an error on the CCD. If the viewfinder is OK, but the screen is dead, the problem is probably the LCD.
Hopefully you still have warranty on the camera?
Oct 02, 2009 | Fujitsu Cameras
Blue screen when using VCR function
Hi and welcome to FixYa,
A blue screen is 'video muting', the player is not getting a decent video signal and rather than display distorted / noisy video, it is muted.  Initially, has a video head cleaner been tried on the camcorder?
Good luck and thank you for asking FixYa.
Aug 02, 2009 | Sony Handycam DCR-TRV80 Mini DV Digital...
Blured viewfinder
Look at the viewfinder on the camera.
Now look on the LEFT side of the viewfinder; just above the swivel-screen.
You will see a little thumb wheel there.
That is the focus for the viewfinder. Move it up and down to bring the viewfinder into focus. (Don't forget to do this while you are looking through the viewfinder so you can see what you are adjusting.)
Easy fix. :)
Sep 29, 2007 | Canon PowerShot S3 IS Digital Camera
Panasonic NV-GS40
the possible fault may be bad image senser CCD. you require a professionl to change the CCD.
Jun 22, 2006 | Panasonic NV-GS17 Mini DV Digital...
Using the camera screen (LCD) as a viewfinder
To use the LCD as a viewfinder: Turn the Mode dial to any Still mode. Press the OK button to turn on the camera screen. Frame your subject in the LCD. Press the Shutter button to take a picture. NOTE: Using the camera screen as a viewfinder significantly reduces battery power. Use it sparingly.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Praktica DC42 Digital Camera Logo
13 people viewed this question
Top Praktica Cameras Experts
Jose Ma DM.
Jose Ma DM.
Are you a Praktica Camera Expert? Answer questions, earn points and help others
