Question about Nintendo DS Lite Console
Scrambled screen when i turn it on, then close & open it the bottom screen is scrambled with multi-colours. does this affect anything? thankyou.
  • 152 Answers
Sounds like your touch screen is broken. Two choices. One: If it still has a warranty, then send it in to Nintendo for repair. Two: Search on sites like Ebay for replacement touch screens, and buy one. Then replace the faulty touch screen with the brand new touch screen.
Posted on Dec 24, 2007
My oven is not heating anything although everything else seems to be working fine. Your site said i may need a multi tester, what is this and where might i find one cheap.
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 04, 2011 | Microwave Ovens
Hitachi C21 model.The colours on screen have got scrambled.
It sounds like something has left a strong magnetic field on the face of the picture tube, and that's causing the colour distortion. The electron beams from the tube's colour guns are hitting the wrong spots on the face. There is a degaussing circuit in the TV that tries to neutralise such fields every time the set turns on. Sometimes electrical equipment (particularly motorised appliances like a vacuum sweeper) operating too close to the TV can leave a field too strong for the degaussing circuit to cope with. Or a failed part in the circuit may have made it inoperative.
A hand-held degaussing coil can be used to remove the field. You can purchase one online, or call a TV service technician. It used to be a standard tool to carry.
Another possibility is that the tube has been damaged. There is a very thin metal mesh screen called the shadow mask behind the face of the tube. If this mask has been warped by a strong magnetic field or a mechanical shock (if the set was dropped, for instance), you will see the same colour distortion. In this case, however, there is no repair other than tube replacement. And that is likely to cost more than a new set with parts and labour.
Jul 26, 2010 | Hitachi C21-F200 21" TV
I have a TRV-35G and the colour is predominately green which I cannot correct across the whole screen with the joystick control. Where the colours of the picture have been corrected (across 2/3 of the...
Try turning colour correction OFF. (button in up position). See what affect the iris control has. This control will changed the color of the slide from deep red at nearly closed to washed-out blue and white. at full open. I adjust the controls for each slide. The color temperature of the 8549 lamp varies with the brightness. lower level warmer, higher cooler.
Dec 02, 2009 | Elmo Projectors TRV-35H Slide Projector
Bottom touch screen has vertical lines all over it
This is a common problem amongst DS lites. It won't go away but it doesn't affect anything so just ignore it.
Jul 11, 2009 | Nintendo DS Lite - Onyx
White screen
i will give a technical help...you open the laptop and re-insert the LCD cable...if it is scrambled the display during start up...maybe it affects when you full down the Ball Grid Array...
Jan 28, 2009 | Dell Inspiron B120 Notebook
Blank Screen
Check the cable to the back of the LCD and also where the cable connects to the motherboard on your laptop. These can come loose over time from the lid being opened and closed and will cause the fault you describe.
If the cable has moved out of the back of the panel itself, then apply a small amount of tape to hold it in place once pushed back in where it should be.
CAUTION NOTE:
These screens are fragile. Take extreme care when inside.
Mar 27, 2008 | Dell UltraSharp 1905FP 19" LCD Monitor
Hi I need to unlock my Sanyo DVD player HV-DX350A
HI this works as i have unlocked my own Sanyo HV-DX350A player with it Hope it works for you
Unlock region code for Sanyo HV-DX350A DVD/Video player.
1. Turn on unit
2. Select DVD
3. Open tray
4. Press 0520 then in sequence press arrow up, down, left and right.
5. The region management screen is displayed on your monitor ( Code is displayed on the unit LCD display).
6. Note - Your current EEPROM region code setting is displayed on the screen.
7. Enter desired Region Code ( 0 for multi region).
8. Press PAUSE to exit.
9. Turn power off and turn on again.
If you repeat steps 1 to 4, you can view your new setting.
Feb 29, 2008 | Televison & Video
Nintendo DS Lite Console Logo
155 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
