Question about Canon imageRUNNER iR C2880 Color Copier
How do I change the drum in a ir2880 copier? I cannot locate the drum units
  • 168 Answers
Open front door lower large blue handle below the toners there is a cover with a latch on it move the latch the door will open the drums are behind that cover
Posted on Oct 06, 2009
Error code E000110-0000 of the copier IR2880
Hi. That error is related to the laser unit . Mabye the shutter of the laser unit is malfunctioning
Jan 19, 2018 | Canon Office Equipment & Supplies
We have paper jump problem.after reseting and changing powder developer.for konic Minolta .bizhub250 bw
So you recently replace the drum? and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 21, 2016 | Minolta Office Equipment & Supplies
Canon ir2880 power is not coming
check the power cord or AC outlet
Apr 17, 2014 | Canon imageRUNNER 2018 Copier
Service manual
Clean or change the drum cleaning blade,check the fuser unit rollers abd the transport belts.Clean the image transfer/separator coronas unit,check ,clean or change the drum antisplit bade,located under drum cleaning blade.
Apr 30, 2013 | Minolta EP1083 CS/PRO Copier
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
Ohp sensor error in ir2880
OHP Sensor may be out of alignment with the reflector in the Paper Feeder Frame Assembly, there may be a loose connection, or it may be faulty.
Open the Right Door Assembly and the OHP Sensor (with a blue tinted lens) is located on the machine side in the center below the registration roller and the ITB. Ensure that the sensor is correctly seated in the mounting frame and re-seat the harness to the sensor. If code will not clear replace the sensor. (RH7-7129-020)
Jan 22, 2013 | Canon imageRUNNER iR C2880 Color Copier
Error 000045 in ir2880
E045 is the HP sensor error located inside the right door. It maybe dirty or dislodged. Clean or replace. No special reset, just OFF/ON.
Canon photocopier iR2016 displaying "waste toner full" on screen. How do I fix this?
Hi there you can empty the waste toner box wich is located inside drum unit.
The procedure is next:
open front cover and leftsideway door
release the blue handle above the drum unit
pull out the drum unit
on top of drum unit, near handle is located plastic grey colored cork
remove it and by means of vacume cleaner clean the vaste toner.
Note that if you flip out the drum unit and try to empty waste toner it could be messy and the toner can get into charge roller or on drum cleaning blade and then you need to change it completly.
hope that hepls
Aug 16, 2010 | Canon iR 2016i Black and White Copier
AFTER changing the drum the unit is putting toner shade on the page like it is over exposed. sShows up mostly when if run through the document feeder
Change the toner antisplit blade (located under OPC drum cleaning blade) and perfor the auto toner density control process.
Oct 08, 2009 | Sharp AR-M205 Copier
AL-1642CS
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of the glass specialy the right side.ok
Apr 16, 2008 | Sharp AL-1642CS Copier
Canon imageRUNNER iR C2880 Color Copier Logo
450 people viewed this question
old marine
old marine
