Question about Garmin eTrex GPS Receiver
Where can I find a system to locate a grid ref in france
  • 121 Answers
www.googlemaps.com is pretty good. Just zoom in close on the spot you want and there is an option to get the grid ref.. I've used this a few times to programme my car gps to get to a location and it's pretty accurate..
www.googlemaps.com
Posted on Oct 06, 2009
SONY KDL-52W5500 red light blinking 13 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 02, 2014 | Sony KDL-52W5500 52 inch Multi-System Full...
GTCO Calcomp 30
You may have an open line in the grid of the tablet and the Quikruler cannot set a point.
Try setting the menu in a different location and check out the grid lines by moving the cursor over the area that won't take a ref point.
Feb 20, 2012 | GTCO Calcomp 30"x36" QuikRuler & Roll-Up...
I have a Dometic rm 2612 RV refrigerator the freezer freezes to 18 degrees the frig cools at nite hoewver durning the day it warms up tu 50 + degrees the freezer remains at 18 degrees. the out side temps...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Oct 02, 2011 | Refrigerators
Ref. still not working after I cleaned to drain plug. freezer is working good
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Also check evaporator fan in freezer
If this was helpful please rate me
Leo Ponder
imufo2
Jul 24, 2011 | Hotpoint HSS25GFP Side by Side...
Driver's seat will not heat
Dear Kevin, check fuses each seat has it,s own fuse. Use a multi meter and check for continuity in both seat and back cushions. Have repaired several hundred lower grids, usually the grid wire breaks at the outer edge from sliding in and out of the seat. If both grids are good try switching l/s switch for r/s. Grids can be repaired by cutting out burnt wire and resoldering ends back together again. This is very thin 30 to 35 guage aluminuim wire about 6 strands. Use electrical solder and a soldering gun. Soldering is the easy part, removing the seat material and locating the grid, some models have grids glued to seat foam, others are sewn into seat covers. This is a nice Sat. job. Kirk fe6fc
Apr 03, 2011 | Ford Explorer Cars & Trucks
How do I download maps of France
http://www.amazon.co.uk/dp/B000WJ67UQ/ref=asc_df_B000WJ67UQ398206/?tag=ciaouk-ce-mp-21&creative=7966&creativeASIN=B000WJ67UQ&linkCode=asn
Aug 01, 2009 | Garmin nuvi 200W GPS Receiver
Using French grid reference system
UTM GPS position format, WGS 84 datum point if my memory serve correctly
Feb 19, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex GPS Receiver Logo
69 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
