Question about Lexmark T644 Laser Printer
I have lexmark t644 printer with duplex unit, but I am unable to print duplex
  • 320 Answers
From ready use the right arrow til you get to finishing menu select it should show duplex select this and then use right arrow to turn the duplex option on
Posted on Nov 01, 2009
SOURCE: Reset Lexmark T644
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Posted on Jan 26, 2009
SOURCE: setting print count on Lexmark T644
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
  • 11 Answers
SOURCE: Reset Duplex Unit Correctly on Ricoh 2232C
Hi There,
The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
Scott K.
Posted on Jan 31, 2009
  • 13 Answers
SOURCE: i have a lexmark t644
  1. If the printer is currently displaying a 900 RIP Software error, power off the printer and leave it powered off for 20 seconds or more. Doing this will clear the printer's memory.
  2. While the printer is off, clear any pending print jobs from the computer or the network queue. This will prevent any corrupted print jobs from being sent to the printer again when it is powered back on.
  3. Power the printer back on.
  4. If the printer goes to the Ready status, try printing again.
  5. If the 900 RIP Software error returns when the printer is powered up or when you try to print, there is a problem with either the printer, the communication cable connecting the printer to the computer, or with the print job itself. Follow the directions below to check each of these components.
    • If the error appears every time you power on the printer, regardless of whether you send a print job or not, the likely source of the problem is the printer or an option installed on the printer.
    • If the error appears only when you send print jobs to the printer, the likely source of the problem is the computer, a setting on the printer, or one of the communication cables.
Posted on Feb 06, 2009
SOURCE: lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
Posted on Jun 03, 2009
Dell 5210n 231.00 paper jam, check duplexer rear door
flag/sensor did not reset, misaligned or broken
Jan 25, 2013 | Lexmark T644 Laser Printer
Installed maintenance kit, t644 lexmark, now it makes knocking\clicking noise while printing. HELP
If you are experiencing excessive noise and vibration, there might be something wrong the Main Drive Assembly and it might need to be repaired. Please call the Lexmark Technical Support Hotline for Laser printers.
Jul 06, 2012 | Lexmark T644 Laser Printer
I have a Lexmark T644 that has printed fabulously using Windows Vista 32 bit until I upgraded to Windows 7 32 bit just yesterday. Now when I try to printduplex the print window that opens no longer give me...
Hi john,
regarding your concern you can try to update drivers for your printer make sure that the driver your wil be installing would be for a Windows7 Operating system having an incorrect driver can cause the printer not to work properly or can cause to lose some functionality having an incorrect driver.
I hope this helps.
mvincentc
May 15, 2011 | Lexmark T644 Laser Printer
Problem in printer lexmark not doplex printing for attiontion manul doplex printing
The duplex unit for this printer is an optional fitting.
If you do not have the optional duplex unit installed then you can only do double sided printing one page at a time manually.
For instructions for manual double sided printing, click on this link :-
http://www.fixya.com/support/r7325259-double_sided_printing_using_single_sided
Feb 10, 2011 | Lexmark T630 Laser Printer
I HAVE GOT AN ERROR 900.00 SERVICE ON MY LEXMARK T640 PRINTER. WHAT DOES IT MEAN?
This link explains error 900 on a Lexmark printer. It includes troubleshooting steps in trying to resolve the issue.
http://www.marketpoint.com/article.cfm?id=100
If problem persists, contact the manufacturer.
I hope this works for you!
Thanks.
Monkey
"Understanding explains better..."
Jan 21, 2011 | Lexmark T640, T642, T644 250-Sheet Duplex...
Lost cd for lexmark t640 - need to install
Download the device-driver software from:
http://support.lexmark.com
Enter 'T640' and do a search.
Click the "downloads" tab to find the drivers (Mac? XP? Vista? Windows 7?).
Feb 03, 2010 | Lexmark T640, T642, T644 250-Sheet Duplex...
Does PCL6 support duplex printing?
This is gona be a helpful website for you
http://search.lexmark.com/printer/US/en/13D0000
Jun 27, 2008 | Lexmark T644 Laser Printer
Lexmark T644 Laser Printer Logo
920 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
