Question about Sony Playstation 3 (PS3) Console
Ps3 slim screen goes black when I select movie or game
I have a ps3 slim hooked via hdmi into a samsung reciever then to my 1080p panisonic tv. The cross media bar will load up fine then I will select to play a fame or movie and the screen goes black. This then requires me to shut down manually and restart the machine. I got the game to play once by unplugging and replugging hdmi from the back of the ps3. Also when I set up my resolution and click the 1080p setting the screen goes black and requires the same thing any help would be greatly appreciated
  • 18 Answers
SOURCE: Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Posted on Aug 19, 2007
SOURCE: call of duty 4 1080p
First off, Sony doesn't make Aquos they make Brava. Sharp makes Aquos. Secondly, I am unable to uncheck 720p how do I do  this?
Posted on Jan 15, 2008
  • 207 Answers
SOURCE: 1080p resolution question
Hey bob do you by chance have a 20gb ps3, if you do then that option is not avaliable to the ps3, I know its crazy but its true if thats not the case let me know i have another Idea that might work but let me do a little more research on it!
Posted on May 27, 2008
  • 125 Answers
SOURCE: Problem connecting HDMI cable
Hey there I don't see why your playstation 3 should be doing that other than the console being defective. Sony doesn't have this problem that often and actually this is the first time i have heard of such problem. Try making sure the the HDMI cable is connected at both ends all the way in and also make sure your Samsung is a 1080P which i am pretty sure it is and finally if you have a friend or another 1080P HDTV in your house i would try and see if your ps3 will support the 1080P feature. If you still have the problem even when you use a different TV then its the ps3 that is malfunctioning otherwise it would be your Samsung. Let me know how that turns out alright.
Posted on Oct 04, 2008
RescueTechLA
  • 2653 Answers
SOURCE: ps3 screen scrolling problem
Go to SETTINGS
VIDEO SETTINGS
and try changing a few of the DVD options like upscalling, dynamic range control, etc.
You might have to set one of these manually to stop the scrolling.
Let us know if you're successful.
Posted on Feb 27, 2009
PS3 pixilation, chopy graphics
You might have to much data on the ps3 try cleaning some stuff off
Oct 02, 2012 | Sony PlayStation 3 Slim Black Console
PS3 problems At home I have a new samsung hd 1080p TV that I normally use for my PS3. I will be in a hotel outa town for the next couple of days and I wanna watch a movie using my PS3. In my...
I had the same problem, stuck in a hotel room for 2 days. When I held down the button, next time I turned it on, I got the same prompt with using HDMI output, said yes, and screen went black. However, a screen then came up asking if I could see the image or not, but it has a 30 second time limit before it saves those setting, you have to click "No" on this screen, and it will drop the resolution to 780p instead of 1080 and it should work! Make sure you're paying attention so you don't miss the screen!
Nov 13, 2010 | Sony Playstation 3 (PS3) Console
When connecting ps3 to Hdmi tv via hdmi lead or av connection ,ps3 is powering up ok but error message appears on tv screen saying game mode not supported.
hello,,when you connect a hdmi you have to into the menu and select hdmi this should give you a 1080p picture mode
regards
shaun
Oct 08, 2010 | Sony Playstation 3 (PS3) Console
PS3 static on screen
It sounds like you're carrying interference to your TV. Try moving you station away from any power source. Make sure your hdmi cable is away from any power as well. This may also be a ground issue. Plug your ps3 power brick into a different outlet.
May 14, 2009 | Sony PlayStation® 3 (80GB) Console
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 Flickers when set to 1080P
It sucks to see ALLLLLLL these solutions, when I have the solution. Turn off DEEP COLOR in the video settings. It will immediately stop. If it doesn't, then you don't have the typical snow/flickering problem.
Oct 02, 2008 | Sony Playstation 3 (PS3) Console
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
May 14, 2008 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Sony Playstation 3 (PS3) Console Logo
234 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
