Question about Hotpoint Aquarius WF220 Front Load Washer
Will not spin, goes through washing cycle but stops before spinning
    Genius:
  • Hotpoint Master
  • 1,474 Answers
If there is water in it clean out filter,,located within Sump hose
Posted on Oct 06, 2009
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Goes through all cycles by will not drain or spin.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
Hotpoint Aquarius WF220 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
