Question about Kenmore 24032\24036 Top Load Washer
It starts to fill,stops starts again to fill, stops and gives an f4 error code
  • Kenmore Master
  • 19,396 Answers
Hi.
F4 means that there is a problem with the pressure switch.
Here an article explaining how to diagnose F4 problem.
Posted on Jan 20, 2011
What does F4 on the display mean?
If "F4" through "F16" appears on the display, there is an electrical problem with the washer. Press the "Pause/Cancel" button twice to stop the washer and press the "Drain/Spin" button to drain any excess water in the machine. Select the cycle again and press and hold "Hold to Start" to restart the washer. This should clear the error and return the washer to normal operation.
If any of the error codes persist, the problem with the washer may be serious. Contact a qualified service technician to repair the washer.
Read more : http://www.ehow.com/way_5389738_whirlpool-duet-troubleshooting.html
Jul 06, 2014 | Whirlpool Washing Machines
LG 2131SH Dish Washer giving error code E1
That is a leakage error, pull the access panel and check for water underneath the unit that might be cuasing it to fault out
Jan 31, 2014 | Washing Machines
2LYMPAIA - F4
Hello
If you have F4 and the sump is full of water, there's a good chance the drain pump is being jammed by a broken bit of glass or pottery. However, if the appliance is empty of water and F4 error code is flashing, where do you go from there?
The electronic control (module pcb) does a self check of the components, during a drain cycle the programme allows a time parameter for the appliance to empty away the water. How does the pcb know the water has gone? Simply by testing a pressure switch for continuity.
The pressure switch is an on or off switch, when the appliance is empty the internal contacts are "made" (on) when the appliance is full of water the switch is "broken" (off).
The sensing grid of the pressure switch is exposed to the dishwasher wash water and can over a period of time get clogged with crud ( a mixture of food waste and detergent and limescale), eventually this crud stops the switch from being in the correct attitude during the self tests. The electronics notes the on or off and determines that the appiiance has not drained and gives error code F4.
If you have F4 error code it could be the pressure switch needs cleaning or replacing.
On the self test about 4 mins is allowed for the appliance to empty the water away.
Aug 03, 2011 | Whirlpool Dishwashers
Error F4
Hello there:
whenever you get this error code F4 or even the f3 error code this is telling you that the ovens temperature sensor/probe is faulty and is unable to sense the temperature of the oven correctly.
So the fix for this is to get a new sensor OK SO IF YOU WILL GIVE ME THE MAKE AND MODEL # OF YOUR OVEN I CAN SEND YOU SOME PART INFORMATION ON THIS OK?
best regards mike
Jan 11, 2011 | Ovens
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
What is F4 error on fisher paykel dishwasher?
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
I have a whirlpool catalyst washer and recently it started blinking an F4 error code..my ? is what should I be looking at when it shows that error code? I have a whirlpool Duet GHW9150P Front loader. When...
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Kenmore 24032\24036 Top Load Washer Logo
302 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
