Picture is concaved colour is off set not running cross screen
  • SD Tech
    SD Tech May 11, 2010
    brand and model number of the TV?
2 Suggested Answers
  • 927 Answers
SOURCE: concave screen blurred picture
Good Day, trinityfaith;;
The RCA is very different then most TV's. It could be one of four boards that's causing this. There is no common one. Please call a Factory Service Center and have give you an estimateb4 repair. Sorry, but Good Luck, big IRISH. PS You are looking at a 4 to $550.00 repair.
Posted on Sep 02, 2008
My sansui rear projection tv's picture is concave with convergence problem also how can i fix it
The convergence can become unstable if you have a failing colour wheel if a dlp set. the same thing can happen if your lamps is beginning to fail the poor frequency of light from bulb disrupts picture. Convergence is usually done by entering service technician code into set through the remote and entering the engineering sub menu and if you don't know what your doing or have a colour pattern generator you could make things considerably worse .
Jul 01, 2015 | Televison & Video
55p9363h/17 The picture has bright spots throughout it and it's not very clear. I cleaned the bulbs and the mirror inside. The screen was replaced also. I went through the contrast settings too. None of...
Do a static convergence on your set. You should be able to go into the main menu and scroll down to picture and press select. Then go to convergence and press select. A white cross will appear use on screen direction to line up all the colour crosses behind thie white cross untill they all appear white. Then press continue and you will see several white crosses do the same for each one of these crosses. this should solve your problem. If not u have some bad convergence chips
Aug 08, 2010 | Philips 55PW9363 55" Rear Projection...
Picture looks concave ,mostly yellow,and double vision on words
Remove unshielded speakers or other metallic objects near the TV. It can cause picture distortion.
  1. Tune the TV to channel or cable program.
  2. Run the TV for at least 30 minutes.
  3. Press FLASH FOCUS on the front panel of the TV.
  4. A cross pattern appears and FLASH FOCUS begins to
    work. The adjustment is completed when the cross pattern becomes white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle. If you perform any other operation while FLASH FOCUS is in progress, FLASH FOCUS operation is canceled.
Oct 30, 2009 | Sony KP-57HW40 57" Rear Projection...
The screen is doubled and pinkish blue kind of like 3-d screen
this is aconverson problum.
first tv-set menu open and select converson option select and see to screen CENTRL cross line in 2 or 3 colour [RED /GREEN /BLUE] hten set on your REMOT cantrol arow key or [ ch+ ch- v+ v-] up down to arow key an set all colour line is meching with centrel and see cross line is complitly waite an d seethe pictur is normal ...
if not converson seting facility in the menu system pls. set your tv-set with tech . he is set menualy sum time's
Oct 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture on projection screen is concave in the middle
This set does not use IC's for convergence. Most other brands do use IC's.They use individual transistors in this one and honestly I don't remember ever seeing these go bad. Normally it is the power supply that runs the convergence transistors or more commonly known as the convergence board. It gets pretty technical with this type of problem. Have a repair shop check it out for you and avoid the headache. Thanks
Jun 07, 2009 | RCA P61939 61" Rear Projection Television
Mitsubishi VS-50501A convergence problem. The image looks like a bow tie and the convergence will not align. This TV only has manual convergence. I already replace the STK391-020 ICs, it has 3 of them....
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 15, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Colours serparated, not converged, screen looks concave
Replace Both fo your STKs convergence ICs STK392-040s. For Parts Call 1-800-223-3205
Dec 30, 2008 | Samsung HC-P4741W 47" Rear Projection...
Concave screen blurred picture
Sep 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
