Question about Sharp Televison & Video
My sharp aquos 40 inch screen keeps flickering, i have had it for 2 months and this is the first time it has done this?
chrispurs1
  • 372 Answers
SOURCE: SHARP AQUOS 32 INCH FLAT SCREEN
Hi.
Easy fix do the following.
Set is in factory mode. To remove follow these steps below extracted from the service manual.
  1. Unplug the AC power cord of TV set to force power off.
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set. The letter K should have disappeared from the screen.
http://dysonmanuals.llc.nu/
Posted on Mar 30, 2008
SOURCE: SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Posted on Jul 09, 2008
SOURCE: Sharp Aquos LC 37HV4U - problems with AVC
I have a fully functioning lc37hv4u box & cable that I will sell for 200$ my lcd got cracked. let me know psxpirate25@hotmail.com
Posted on Aug 01, 2008
SOURCE: 37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
Well I tried a cable amplifier & that solved my problem. I now get all HD channels without an HD cable box.
Posted on Oct 19, 2008
  • 100 Answers
SOURCE: Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Posted on Jun 04, 2009
Flickering Sharp Aquos tv
it really depends on were the flicker is, if its the backlight or the screen, flicker can mean them both, t-con board only controls the screen out put on lcds, but on plasmas it works with the back light inverters. if the screen is white and not flickering while looking at the back of the screen on an lcd then it could be the t-con board failing it could also be a bad connection to the board from the wires. the plug were the main board connects to the t-con board if you have the back off and wiggle the cable and see if it stops the flicker.
Aug 08, 2017 | Sharp Televison & Video
Sharp aquos LC-60LE640U flashing error code 2-5.
Dont buy a Sharp. Buy a Sony, Panasonic, JVC, Visio, ANYTHING but sharp!
Jan 27, 2013 | Sharp LC-60LE640U 60 Inch 1080p 120Hz LED...
I have a 52 inch sharp aquos the screen is broken can I replace it
It will be expensive and time consuming, but it can be done. There are many web sites that sell replacement screens. Just google TV replacement screens. You should download the service manual for your TV from Sharp's website before attempting to do the repair.
Oct 14, 2012 | Sharp LC52D65U Aquos 52 inch 1080p LCD...
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do i Adjust My 40 inch Sharp Aquos to 1080 p?
You do not adjust the resolution at the TV, the TV will adjust itself to display what you are feeding it. It works the same way as the computer monitor, which is done on the computer's video card to what ever you set it to.
Nov 09, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
Jul 24, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Dec 24, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Flicker
I have the same problem when going to dark scenes from a bright scene or during channel changes. Sharp sent a tech under warranty and he installed new software to no avail. He called sharp tech support and they suggested turning on opc. The TV works fine but you must adjust sharpness and contrast to achieve an acceptable picture. I paid $868.00 for the set a Sam's club and will buy an extended warranty. I will not buy another sharp. My 40" sony works perfectly.
Oct 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
565 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
