Error Code 19
The Slimtype DVD A DS8A1H ATA Device (running Windows Vista SP2 HP Pavilion Laptop) had Error Code 19, so I went ahead and uninstalled, restarted,and it wouldn't re-install.
It says:
''Please consult with your device manufacturer for assistance getting this device installed.''
Now what?
Thanks for any help!
Under Device Manager, it still has code 19...(the drive is a dual cd/dvd, too)
    Top Expert:
  • Computers & ... Master
  • 26,781 Answers
Replace the drive if it has not become unplugged.
Posted on Jun 26, 2017
4 Suggested Answers
Vladimir Z
  • 86 Answers
SOURCE: The device (Windows Vista SP2 HP Laptop) had Error
try going into safe mode and install it there, let me know how it ended up
Posted on Oct 06, 2009
in9876388918
  • 170 Answers
SOURCE: slimtype dvd a ds8a1h ata device can't read hp
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/) How to back up and restore the registry in Windows
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
  • Click StartStart button, type regedit in the Start Search box, and then click regedit in the Programs list.
User Account Control permission If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  • Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4 D36E965-E325-11CE-BFC1-08002BE10318}
Caution
There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  • In the right pane, right-click UpperFilters, and then click Delete.
  • Click Yes to confirm the removal of the UpperFilters registry entry.
  • In the right pane, right-click LowerFilters, and then click Delete.
  • Click Yes to confirm the removal of the LowerFilters registry entry.
  • Exit Registry Editor, and then restart the computer.
Note: After you remove the UpperFilters registry entry and the LowerFilters registry entry, you may lose functionality in certain programs such as CD recording programs. In this scenario, you must reinstall any affected programs. If the problem recurs, contact the program vendor to determine whether an update is available for the program.
Worked for me
Posted on Feb 01, 2010
  • 91 Answers
SOURCE: Please help, my ''SLIMTYPE DVD A DS8A1H ATA DEVICE'' won't work.
First use the following steps:
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
If it fails, there is a manual method to edit the registry. Let me know so that I can follow up further.
Posted on Mar 10, 2010
Slimtype dvd a ds8a1h ata device is not working. Previously worked fine. Now i get a 'Power calibration error'.
"Power Callibration Error" is the result of low laser power.
Open the DVD drive and carefully, with a cotton bud, rub the laser lens gently in a circular motion.
Try again.
If still faulty, replace the drive.
Dec 15, 2010 | HP Pavilion dv6000z Notebook
Slimtype DVD A DS8A1H ATA is not burning
make sure that the dvd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this dvd rw then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your dvd burner or uninstall the driver then reinstall for this device
or you might have to uninstall the burning software then reinstall your burning software
hope this helps
Dec 10, 2010 | Sony (DW-D22A/B2) DVD±RW Dual Layer...
I have a slimtype dvd a ds8a2s a ata device that I get a code 19 device cannot start message in device manager
Fist, go to devise mgr, --start button, in search area type devise,
find the devise, it should have a yellow shield, click on expand so you see the actual drive, it could be open with the shield next to it already.
It will be under cd roms. right click on it and choose uninstall, yes
uninstall the devise, now cold boot , shut down the computer and restart
it and wait until windows says found new hardware, if it doesn't throw the error when installing or after installing, go back and check it for the yellow shield.
Feb 08, 2010 | Acer Computers & Internet
I have a slimtype dvd a ds8a2s a ata device that I get a code 10 device cannot start message in device manager I have tried to re-install the driver and downloaded any updated drivers and get same message
From your description I understand that the DVD drive is not working and you have code 10 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Jan 10, 2010 | HP Compaq Presario CQ60Z Notebook
Drive needed for my dvd drive(Slimtype DVD A DS8A1H ATA Device)
Here is a link to all your drivers you can try reinstalling it from here, click here for page. hope this helps
Dec 02, 2009 | HP Pavilion dv2000t Notebook
Code 39 error
It's a drive problem,Uninstall the DVD device,Then restart and let windows install it again.
Jan 05, 2009 | Microsoft Windows Vista Ultimate Edition
Pioneer DVDRW DVR-K17B ATA Drive
This is my error in report viewer for my dvdrw in laptop.
dvdrw icon is hide and it can't read any disk dvd/cd.
PLEASE HELP ME! THANKFUL
" Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
Aug 06, 2008 | Pioneer DVR-107D DVD±RW Burner
Slimline DVD Burner
Go to the device manager. uninstall the dvd drive .restart computer after turning the power off. re-install the device from add hardware wizard.restart computer.this may solve the problem.
Jul 08, 2008 | Computers & Internet
Slimtype DVD A DS8A1H не пишет и не стирает dvd-rw...
I want Cd&DVD burner free software please send the my mail
another Id : skatumala@gmail.com
another Id : katumalas@gmail.com
Jun 21, 2008 | Computers & Internet
Computers & Internet Logo
433 people viewed this question
David Payne
David Payne
