I have an older peavy 2000 amp and one of the clip lights are on and that chanel dont work
    Genius:
  • 1,144 Answers
Internal
Posted on Oct 11, 2009
My peavy amp will not turn on
1- check the outlet for power by plugging in a lamp or something
2- check the amps fuse. Most power amps have user replaceable glass fuses.
Aug 17, 2012 | Peavey Bandit 112 Guitar Amplifier With...
The SP5G Peavey Speakers are a good combination for the MP5 Plus?
Those speakers are capable of much more power than that little powered mixer can deliver - my 5G's are rated for 800 Watts program. I use a pv2600 to drive mine - at 8 ohms per side that's a good match. Depending on what your using the setup for...my concern would be that a small amp like that could get turned up high enough that you'll be clipping - thereby sending nasty squared waves at the speakers - they won't like that much. If you want much volume - you should look at a bigger amp. If you're going very low key...those speakers are overkill.
Jun 08, 2012 | Music
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
Older peavy 4 string bass with batteries need wiring shematics
I think posting the wiring schematics is not legal. If it just does not work anymore you could try and look if the battery clip is oxidized and try to clean it.
Feb 27, 2011 | Peavey Millennium Bxp 4String Bass Guitar
The drivers windows dont work properly. I have to push hard up and down to raise and lower the windows.
Try some silicone window lube in the chanels. Lube the metal tracks too. If no change & the problem has been getting worse gradually, then replace the motor.
Jan 10, 2011 | 2000 Mercury Villager
My peavy has three lights at power on when in use red light comes on is that beacuse my amp is overheating or is it normal it does that when i crank the volume amp i not hot well vented
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00512180.pdf Page8 sections 2 through 4 discusses the LEDs. I think what you arte talking about is the DDT active LEDs. Page 12 specifically discusses this and page 15 notes that Red signifies DDT clipping. Peavey recommends that you don't defeat the DDT circuit and that is good advice as it protects your amp and your speakers. The clipping is not caused by the amp but by the amount and quality of signal being input. Check earlier in your signal chain for the cause.
Aug 14, 2010 | Peavey Pv 2600 Power Amplifier
Shashij_2001@yahoo.com
TURN THE BALANCE CONTROL IN THE MIDLE
Jul 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
Peavy amp 2000 will not power up or reset
disconnect all input and all output and check if the problem solved you will have an problem in surrounded world-start with one input and one output speaker and check if it is ok go to next speaker until you find the bad one-----if all above failed your amp needs to be inspected in service center.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Plug in Numark mixer & twin CD player to a Peavy CS 1200 x amp. There are diagrams but im lost
simple.numarks outs to peavey's inputs.probably rca's to quarter or rca's to xlr's
Dec 08, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
