Question about Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 3 squeaks.
We have a IBM Wheelwriter 3 that when the paper advances it squeaks. The thought is maybe the roller needs cleaning but how should we go about that? Can it be removed for thorough cleaning? Is there maybe some other component that should be looked at? Is there a manual available?
  • Lexmark Master
  • 3,594 Answers
I don't know if you have fixed your squeek, if not lift the erasure table (plastic piece that goes all the way across and sits on the platen) if it goes away put a few thicknesses of tape on the contact points on each end.
DickyO
Posted on Oct 23, 2009
    Champion:
  • 204 Answers
The squeaking is caused by lack of lubrication on the Platen (roller) bearings..the feed rolls that grip the platen or the linespace mechanism. Have to be careful on too much oil..I just put a drop on a corner of a piece of paper and touch what you want to oil..it will **** the oil right off the paper. a light oil like gun or sewing machine oil.
Hope this helps
Squipps
Posted on Oct 08, 2009
Need help with wheelwriter 3 which is not printing. Works but nothing on paper
See page 3-5 @
http://www.national-elec.com/IBM%20&%20Lexmark%20Typewriter%20operating%20instructions/Wheelwriter-3sII.pdf
Sep 06, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Wheelwriter 30 paper advance
The paper release lever may be in the release mode. try holding the left platen knob and pulling lightly on the paper is should not allow the paper to move freely, if it is ok try holding the left knob and turning the right knob in the direction you would to turn the paper in it may have come loose if so turn it all the way back in do not over tighten it your machine does not click when the platen is turned it uses electronics to hold the platen on line.
credits : JUSTOLDJIM
thank you
Aug 08, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 - Ribbon doesn't lift high enough for the key that's pressed to print on paper. Ribbon advances OK.
If theribbon dosen't lift at all see if the black gear on the R. side of the printer will move, if not w3iggle it and it should free up they get tooth for tooth with the motor gear. If it only lifts partually thereis an adjustment on the roll that works with the black gear. BE SURE TO CHECK THGAT BTHE PLATEN IS FULLY SEATED IN THE VSIDE FRAMES THEY DO GET LOOSE!
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
I got a label stuck on the roller of my ibm wheelwriter 30. the only way to remove the label completely will be to remove the roller. How do I remove the roller or is there any easier way to remove my...
While I haven't seen your model of machine in many moons, the roller was generally not difficult to remove once the plastic housing was removed.
If it appears to be a bigger job than I recall, you could take 1/4 - 1/2 sheet of plain paper, saturate it (not dripping) with naphtha (lighter fluid) and feed it into the machine to cover the label. Allow some time to soak, feed the paper out and wipe the residue of adhesive with a clean lint free rag several times, wetting it if necessary with a few drops of naphtha to complete the removal.
You might feed several clean sheets of paper through before using to ensure no residue or fluid has stayed behind.
Aug 06, 2010 | IBM Wheelwriter 30 Typewriter
No user manual for my IBM Wheelwriter 6
You can download the IBM Wheelwriter 6 series II 6784 Operator 's Guide from Lexmark site (look for "IBM Typewriters" in the bottom of the page):
http://images.lexmark.com/publications/pdfs/2007/index/en.html
If all you remember is the # 80, maybe what you have to do is insert the the paper in the machine and then press [PLAY] + the number 80 and, then, each time the playback stops at a stop point, type the variable text to be inserted (check the " Playing back a repetitive letter" section of the manual).
You can also get a print "directory" of all text stored (check the "Advanced Storage" chapter).
Hope this helps.
Jul 23, 2009 | Lexmark Office Equipment & Supplies
Paper not advance
THE ROLLERS MAYBE DRYED OUT AND THEY NEED TO BE RECONDITIONED, OR NEW RUBBER PUT ON THE ROLLERS.
THERE IS A WAY TO TURN THEM DOWN YOUR SELF BUT YOU COULD ALSO MESS THE EVENINGNESS OF THE ROLLER, A SHOP THAT WORKS ON PRINTING PRESSES MAYBE ABLE TO HELP YOU OR IBM SERVICE CENTER MAY HAVE SOME OTHER IDEAS OR DO THEY EVEN MAKE PARTS FOR THAT PEACE OF EQUIPMENT.
ROD
Apr 16, 2009 | IBM 6400 Matrix Printer
IBM Wheelwriter 6 memory loss
If you have changed the batteries the battery holder is probably corroded, take a piece of fune sand paper and clean the contacts, put the batteries in and spin them around to help them seat.
DickyO
Dec 08, 2008 | IBM Wheelwriter 30 Typewriter
IBM Pers. Wheelwriter 2 Ques
check the position of your paper drum maybe he is little uper or not on the place.
May 08, 2008 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
150 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
