Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Craftman 18hp briggs @srat starts then cut off when it gets hot
The lawn mower runs then cuts off wait a few min. then it starts it must be a electrical problem i have by passed every switch replaced coil [armature} the only thing left is the altanator
    Scholar:
  • 110 Answers
I hope all that time and money was worth it - there are classic symptoms of a blocked gas cap vent. Vacuum forms in tank - no fuel flow - engine stalls. Wait a bit - air leaks in, engine starts again (for a while.....).
To completely elimnate a chassis wiring issue, simply disconnect the mag cable from the engine. The only possible culprit if there are still electrical problems is the coil itself - which you already replaced.
Posted on Oct 06, 2009
Turn zero
sorry but i would talk to the shop about that.
Jul 30, 2013 | Ariens Zoom 42 In 165 HP Briggs Stratton...
2011 polaris ranger cutting out
clean carb and all fuel delivery system lines
Mar 25, 2013 | Polaris 2011 Ranger 800 XP EPS
Repairs on craftman lawnmower 917-377-550
Sounds like someone cuts the grass when it's to wet for that much to build up
Mar 23, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
My cub cadet wont restart after it gets hot
what engine do you have and how long has it been doing it for, try a new plug at first.
Jan 10, 2013 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
Champion 35 petrol mower keeps cutting out
im a lady so im a bit out of my league don't know where air filter
is
May 02, 2012 | Briggs & Stratton Garden
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
2005 Poulan PD17542LT Lawn tractor, It starts fine but after cutting my front yard (20-30min) it dies, it will start up but dies in a few sec. If I let it set and cool off I can get 20=30 min till it gose...
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
Jun 22, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
When mower gets hot it cuts off crank back up run a min cut off
1 of 2 things happening
first change the fuel filter seams that the gas is vapourizing
If that does not fix it replace the engine coil as it heats up it is breaking down in voltage causing the engine to die
Apr 05, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
394 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
