Question about Kenmore 24032\24036 Top Load Washer
Kenmore 500 top load washer starts to fill withwater then stops
At the begining of a regular cold water cycle it starts to fill up with water then the machine just stops.
  • 5,911 Answers
This is commonly caused by a lid switch malfunction. If the washer fills, agitates, then stops at the rinse and won't drain, or if the washer does an initial fill, then stops, this is a symptom of a lid switch malfunction.
The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
If the lid switch is found to be defective, it can be purchased at any of the following websites:
searspartsdirect.com
applaincepartspros.com
pcappliancerepair.com
repairclinic.com
The average price is $25 to $35. Prices vary between these sites, so shop around for the best deal.
This is a very simple repair, but if you still have questions, please let me know. I hope this helps you.
Posted on Oct 06, 2009
Kenmore 500 fills with water but wont agitate
Posted on Apr 25, 2010
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Star washing went get to rinse circle stop, press stop bottom and start bottom tries to start but not work
if you're saying it dies in the rinse cycle you could have a problem with your cold water not coming into the washer,the washer only uses cold water in rinse cycle,no cold water the washer won't run,try starting it just with cold water and see if it fills,if not bad water valve or problem with water in house valve or bad hose.
Apr 08, 2013 | Kenmore 24032\24036 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
    You may have 2 defective parts.
    First,make sure the hot and cold water hoses are connected correctly and both turned on.
    If the water fill problem is the same,the water temp switch is bad.
    The not filling after the wash cycle could be a bad lid switch.
    Set the machine for SPIN and turn it on.
    If it does not spin,replace the lid switch.
    Sep 20, 2010 | Kenmore 24042 Top Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer keeps filling with water...
    you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
    Jan 11, 2009 | Kenmore 22422 Top Load Washer
    Kenmore Elite Calypso washer won't fill with water!
    i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
    Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
    70 series Kenmore washer
    POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
    IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
    Mar 31, 2008 | Kenmore 22422 Top Load Washer
    Kenmore 24032\24036 Top Load Washer Logo
    1,017 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
