Question about Posiflex Jiva 5800 All-In-One (tp5815r2w2k) Network Terminal
Broken screen The glass under the touch screen has shattered. i don't think the screen itself was effected. IS there any way to replace the underlaying glass?
  • 82 Answers
Yes, you can replace the touchscreen glass
Posted on Aug 27, 2010
My LCD HGTV flatscreen was bumped up against something when moved, now has shatter like image on screen, glass itself not broken...can it be repaired?
No, the display panel which is very fragile is now damaged and the part will cost more that the set did or a new one will cost to replace this one.
Aug 30, 2012 | LG Televison & Video
Picture tube is discolored almost like a shattered glass appearance?
That shattered looking glass effect is your LCD panel shattered. Your panel needs to be replaced. Would be more cost effective to replace your TV.
May 12, 2011 | Vizio L32 32 in. LCD HDTV
My son head hit the bottom left corner (near corner) there a crack in the glass but doesnt look to deep but now tv wont turn on
Sorry this tv can't be repair the Plasma screen panel is dead.The Plasma screen crack causes the radiations leakages,that why tv screen can't sustance the radiations at all to be able to light up,even tv still have enough radiations to light the Plama screen internal screen menbrance will have a big cracks like a spider web or a huge shatter like a car windshield broken glasses within it safety plastic shield.The tv Plasma screen panel is 90% inportant functions to the tv,by replacing the Plasma screen panel,will cost the same as a new tv,sorry this tv now only worth as a salvage tv for it eclectronic boards for parts,that it.
Jan 27, 2011 | Panasonic Viera TH-42PX80U Plasma TV
MY ipod touch has black dots all over the front and the touch screen doesnt work but the menu button does work and it turns on but i cant unlock it after i turn it on... I tried turning it off but since...
If you have black dots one of two things is broken
  1. The Video Controller is broken
  2. The LCD is broken
If you cant use the touch then the issue is a broken or disconnected touch panel (The touch and LCD are two separate components)
This is easily fixed for about $100. I replaced mine after a fatal fall shattered my front glass. and components.
If you are not tech savvy, call Apple they can fix it, but if your not covered by warranty then it'll cost you A LOT!
Aug 21, 2009 | Apple iPod touch
The touch screen on our Garwin Nuvi 360 do not function.
Unfortunatly there is a fine wire Grid below the surface of the glass, the grid detects where you are touching on the screen, with the glass being broken, the grid is broken, which will cause dead spots or regions on the touch screen. You will have to replace the Touch screen or the unit which ever is most cost effective.
Hope this is of some help.
Ed
Apr 18, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Garmin c330 fell and the outside glass to screen is not broken but the layer under it is shattered. it powers up but touch screen does not respond. is this something i can fix myself?
No, you will need to replace the LCD screen. Unfortunately, Garmin will charge you almost the price of a new unit for fixing it. You might be able to find a used unit on eBay that is dead but has a working display and swap the displays but it requires some electrical & mechanical knowledge.
If I can find a display, I can put it in for you for a reasonable price.
Please let me know if I can be of further assistance to you.
- Jim
Jul 12, 2008 | Garmin GPS
LCD Sanyo screen looks shattered
The inner glass plate inside the screen is broken. The glass inside of these is very thin. I think it is only a few millimeters thick at the most.
The complete screen must be replaced to fix the fault. It will probably be cheaper for you to buy a new monitor rather than replace the screen!
Jerry G.
Jun 02, 2008 | LG 42LC2D 42 in. LCD HDTV
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Posiflex Jiva 5800 All-In-One (tp5815r2w2k) Network Terminal Logo
88 people viewed this question
Top Posiflex Computers & Internet Experts
Jason Morris
Andre Fourie
Level 1 Expert
Are you a Posiflex Computer and Internet Expert? Answer questions, earn points and help others
