Question about Philips Magnavox 51MP392H Rear Projection Television
The screen is doubled and pinkish blue kind of like 3-d screen
  • 83 Answers
This is aconverson problum.
first tv-set menu open and select converson option select and see to screen CENTRL cross line in 2 or 3 colour [RED /GREEN /BLUE] hten set on your REMOT cantrol arow key or [ ch+ ch- v+ v-] up down to arow key an set all colour line is meching with centrel and see cross line is complitly waite an d seethe pictur is normal ...
if not converson seting facility in the menu system pls. set your tv-set with tech . he is set menualy sum time's
Posted on Oct 06, 2009
Lower screen is pinkish
The screen's backlight is dying. Sooner or later this screen will be pinkish and later it will be darker and black. You need to replace the whole screen (it is not easy to replace the backlight).
Feb 28, 2014 | Toshiba Satellite L510 Laptop AC Power...
MY LAPTOP WONT GO ON AND THE BATTERY HAS A PINKISH LIGHT
The battery has a pinkish light or the laptop screen has a pinkish light? When the screen has a red or pinkish tint to it, and is black still, it is the LCD inverter that is the problem. The computer and the LCD screen work fine but you need to change the inverter. It happens very often and you can find inverters for your specific laptop online and certainly on eBay.
Apr 02, 2010 | Computers & Internet
Blue streak now double vision on outside.
coversion amp ic have died you need to call al tech to replace them parts are cheap but labor is going to get ya
Sep 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
3-d looking picture on top and bottom of screen
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 25, 2009 | Philips 51PW9363 51" Rear Projection...
Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Philips 17pf8946/37 has no video
Phillips LCD TV 17PF8946/37, has no picture at all on the screen, even menu and channel #s not showing in the screen. The screen just have blue color. Everything is working like switch & video. Please let me know what parts need to be replaced and where can I order the parts.
Nov 15, 2007 | Televison & Video
My toshiba tn61x81 projection tv
have you tried the convergence option in the menu? i believe it is under "picture". this allows for nine different sections of the screen to be adjusted when projection images get out of whack.
Oct 20, 2007 | Toshiba TN61X81 61" Rear Projection...
Limited blue
your tv has a fault in the matrix board the blue driver volt to the screen is missing or some dried up soldering at a pin should be seen by qualified , but sereen is ok , regards please don't forget to rate thx
Apr 28, 2007 | Toshiba TP43H60 43" Television
Philips Magnavox 51MP392H Rear Projection Television Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
