Question about Garmin Nuvi 350 Car GPS Receiver
How do I set the Garmin Nuvi 350 interior antenna? My GPS no longer locates satellites.
  • Garmin Master
  • 2,130 Answers
The internal antenna/GPS is defective and needs repaired/replaced. Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Oct 08, 2009
Hi, My Garmin nuvi displays 'gps is off' which means i am unable to de directed correctly as its saying im in the middle of no where. Please can you help? Thank you Laura
There are two possibilities as to why your GPS is not responding.
The first is to check your System Settings. Although it should not affect your GPS signal, check to see if the WAAS / EGNOS setting was turned off. If so, try turning it back on.
The other possibility is that the Garmin device is not reporting the status of your antenna properly. When the Antenna is closed on the nuvi 350, it disables the GPS functionality. Simply open the antenna to re-enable GPS. If the antenna IS open, there could be a hardware malfunction. This would require contacting Garmin for additional assistance.
Contact details for Garmin can be located at http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 27, 2011 | Garmin nuvi 350 GPS Receiver
MY Garmin first Said that it was acquiring a satellite then it is stuck in one city and won't clear to set another route. what can i do?
Did it actually acquire any satellites. If not try the reset button on the back. If nothing then do a master reset - you may lose some of your locations previously stored or user data. If none of these work or before you try them try an external antenna.
Oct 24, 2009 | Garmin Nuvi 350 Car GPS Receiver
My Nuvi 350 takes 15-20 minutes to acquire satellites. Is there a change in settings that I could make to speed this up? Richard
Having worked on quite a few of these, your flip-up antenna/GPS receiver may have a problem. There is a part that fails that affects reception and eventually it can lead to full loss of satellite signal.
Please see this link for more info:
- Jim
Sep 24, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 300
did you changed any setting in your device.if no then it could be the antenna nor receiving proper frequency.
Nov 24, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi starting location is wrong
I tried to fix a problem similar to this for 1and 1/2 hours. Ahhh! However, after raising the antenna, (in back of device), the satellite picked up my exact location. Hope this helps.
Nov 23, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 360 - Acquiring Satellites
Did you check to make sure that it is not in demo mode?
I've seen complaints that the unit is not working, and it was in demo mode.
If everything is set up properly and it still does not work, you will most likely have to send it to Garmin in the US.
Jerry G.
May 28, 2008 | Garmin nuvi 350 GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
Garmin 350
There is an issue with the flip antenna's, try a external antenna. The Quest and Quest II suffer the same problems
Apr 10, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 310 satellite aquire problem
I have a Garmin Nuvi 350. I solved the problem by purchasing a Glisson GPS antenna that plugs into the external GPS connector on the Garmin antenna.
Apr 04, 2008 | Garmin GPS
Garmin Nuvi 350 Car GPS Receiver Logo
132 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
