Question about Sharp Televison & Video
Flashing red lights on sharp LCD TV
Flashing red lights on front of sharp lcd tv. No picture
4 Suggested Answers
  • 367 Answers
SOURCE: 15" lcd tv...no picture
Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Jan 04, 2009
  • 53 Answers
SOURCE: Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Posted on Mar 20, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
My Sharp 19" LCD Tv
Bad capacitors in the power supply are common on most of these small Tvs. I have not repaired this model, but my suspicions and expeience tell me where to start! Thanks for asking and show all hands of support!
Sep 13, 2011 | Sharp 19 in. LCD HDTV
Never a problem, even last night. Now, won't turn on. Checked all connects and plugs. Unplugged, pressed 'clear'. Still just a solid red light. Sound comes through fine. Even tried all new batteries.
Tv now turn on,u have a flashing picture only a few sec. than dies have sound left only?Yes,than the tv long board call the LCD inverter board is dead.The tv have 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Feb 09, 2011 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sharp LCD flashing red light and no picture
yes thats is a common problem for all flat tv not only
sharp ;/ first theres is capacitor in power supply
you probly have few one there blow up and it could bee from the power section of your back light circuit
a good technician can fix that easy
good luck
Apr 02, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Red ir light floashing and tv wont come on Onn lcd tv
red light flashing on bottom of tv and no picture
Nov 27, 2009 | Televison & Video
Lcd tv
Hi!
Sounds like you have a bad power supply board! This is not hard to do yourself, as long as you are somewhat handy! Take the case apart (back side), and look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain).
If you see this problem, you can buy a new power supply at www.shopjimmy.com or ebay. You will need the make and model, of your tv to order! Good luck, I hope this is helpful!!
Mar 08, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos red flashing light tv won't get picture
if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Nov 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv not working
i have the LC-26GA4U LCD TV & mine has the exact same problem. I brought it to an authorized sharp tv repair shop it turns out its the LCD panel. the panel costs $1700 & with labor installed it comes to $2055.43. almost exactly what I paid for the tv 2 years ago. good luck. Mike
Jul 11, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
190 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
