AC line interference
I seem to have AC line noise imposed on my tranceiver's output signal and need a solution. My transceiver is a Yaesu FT-840 brand.
    Habit-Forming:
  • 29 Answers
I experienced very similar or the same problem with FT-840. When power is inceased over about 50 W, an AM on RF signal arises. Even when TCVR is supplied from accu and connected to dummy load. Period of interferencing signal is about 7.5 ms (130 Hz), so it cannot be hum from mains. I have not opened the PA block yet but i guess, it could be caused by damaged capacitor(s). Jiri
Posted on Dec 07, 2011
How to wire a audio mixer deck to a radio tranceiver
I'm not sure if you want it wired to the input or output. You can connect the output of the transceiver(if it accepts an earphone plug) to the the input of the mixer using plugs you can buy form Radio Shack or MCM electronics on line.
Oct 06, 2014 | Yaesu FT-8900 Quad Band Transceiver
Transceiver signal interference
The FT-840 uses a die-cast RF power amp with thermally switched fan to ensure full power output (up to 100 watts). The digitally synthesized local signals ensure clean, low-noise transmitter output on all HF amateur band. There might be no AC line interference. it has strong Rf output. any AC line intersect does not affect its radio performance. Check and adjust RF power so to maintain proper output. some times more RF power generated at the output may cause interference. adjust Rf power..Even some unfiltered Noise getting the other end of the end may calso cause interference. Check for any Ripple voltages present at the output. Contact authorised service station for further Rectification. thank you shanth
Dec 23, 2007 | Computers & Internet
Yaesu service manual
The external VFOs for the FT400/401/560/570 (ie "F line" transceivers) are all fairly similar.
Fox-Tango manuals library
http://www.foxtango.org/ft-library/FT-Library/60s-70s/60s-70s.htm
Look for FV-401 listed under FTdx-400 transceiver
Antique Radios discussion of Yaesu Musen vfo
http://www.antiqueradios.com/forums/viewtopic.php?f=5&t=238656
Dec 15, 2013 | Radio Communications
Indicates SWR when I know the antenna and the dummy loads are 50 Ohms; so it reduces output.
Then there should be an internal unit problem in the swr detector line like a bad diode or a bad connection between it and the output coax connector.
Aug 27, 2013 | Yaesu FT-857D transceiver
Software Menu Aligment yaesu FT-857
http://www.hampedia.net/yaesu/ft-857-second-menu.php this link lists the settings to put back to factory abc together when switching on to access
Apr 10, 2013 | Yaesu FT-857D HF/VHF/UHF Mobile...
Yaesu ft 840
Check on www.mods.dk. They have lots of manuals
Apr 02, 2013 | Yaesu FT-840 Owners Manual
Nice rig, what's the question?
Aug 09, 2012 | Yaesu FT-857D transceiver
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
Reinstating Yaesu 707 transceiver to original 100watt output
check the resistor values around the finals and also around the stage that drives the finals and see if they differ from the schematic values.
May 29, 2009 | Yaesu POWEREX MH-C500Y Charger for FRS...
Computers & Internet Logo
108 people viewed this question
Alun Cox
David Payne
David Payne
