Question about Kenmore 98702 Stacked Washer/Dryer
WASHER FILLS UP ABOUT HALFWAY WITH WATER THEN IT DRAINS OUT WHILE WATER IS STILL TRYING TO FILL. GOES THROUGH THE REST OF THE CYCLE LIKE THAT
  • 304 Answers
One of two things to check should solve your problem.
  1. Check to make sure that SOME part of your washer's drain hose is looped higher than the flat top of the washer.
  2. Check to ensure that the end of the drain hose is not stuck too far into the house drain to create siphoning of the water in the tub.
Both of these can be eliminated as the problem by pulling the washer hose from the drain and aiming it into the tub of the washer by lifting the lid or into a tall trash can higher than the lid of the machine. If the machine works when doing that then ONE of the above problems is your cause.
Good Luck
Posted on Oct 06, 2009
Hi, I am trying to help daughter-in-law get their
Hello annp, thank you for your post! Based on the symptoms you are describing, it does sounds like a siphoning issue. Generally speaking, the drain hose should come up above the washer tub and please make sure the drain hose is not too deep in to the house drain pipe. The drain hose should only be submerged 4-8 inches into the house drain pipe. If correct, otherwise the unit might be experiencing a communication with the control board and water fill valve. At this point, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - please do not hesitate to reconnect.
Jul 31, 2013 | Frigidaire FGX831C Top Load Stacked Washer...
The washer only fills halfway up during rinse cycle only, even on high water setting. it fill completely during the wash cycle.
Has it always done this or just recently? Some washers have lower rinse fills then spray the water on the clothes as it goes through its cycle.
Sep 24, 2011 | Estate Washing Machines
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool washer - tub drains while it fills.
Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
Aug 15, 2009 | Whirlpool Washing Machines
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
WATER ONLY FILLS 1ST TIME ON ANY CYCLE
Hi, After the first cycle, and after it drains/spins, does it start agitating when the next load of water is suppose to be filling?
Please let me know so I can assist you further. Sounds like the pressure hoe from the tub to the water level switch is plugged.
Thanks
Vic
May 17, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Machine fills with water & then clicks but goes no further. It will drain but no other function seems to work
That is probably a problem with the timer.
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Oct 11, 2008 | Bosch Washing Machines
    Kenmore stack washer and dryer
    gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
    Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Washer fills then drains
    Daisy, check your drain hose going into the drain. It sounds like you have a siphoning problem. If the drain hose does not have a air gap the water filling will siphon right out. Check this first and post back, Catriver.
    Sep 21, 2006 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore 98702 Stacked Washer/Dryer Logo
    61 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
