Question about HP OfficeJet 4215 All-In-One InkJet Printer
How do I put new cartridge in - HP OfficeJet 4215 All-In-One InkJet Printer
    President:
  • 1,188 Answers
Follow this procedure to install print cartridges in you printer.
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the tape by using thhow do I put new cartridge in - 8cab956.jpg tab.
Caution! Do not touch the gold-colored contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into thehow do I put new cartridge in - 704c31c.jpg>It must slide in at a upward slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
Caution! Do not attempt to pushhow do I put new cartridge in - 6c2c861.jpgdge straight into the slot.
It must slide in at a slight upward angle.
Note: You must install both print cartridges in order for your HP Officejet to work.
6 Close the print-carriage access door.
“Press OK to print Align page” appears on the display.
7 Press OK.
Posted on Oct 06, 2009
  • Adnan Bhatti
    Adnan Bhatti Oct 07, 2009
    Please comment; why the provided solution did not help you install a cartridge? Was there something deficient?
HOW DO I CHNGE THE CARTIDGE.?
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink cartridge appears in the display, replace the print cartridge. The part number for replacement cartridges is HP 20.
1. Take out a cartridge from its packaging and carefully remove the tape covering the printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
3. Open the control panel and cartridge compartment cover (it will click and remain open).
4. Pull the cartridge toward you and remove it.
3 To load the cartridge insert the cartridge as shown below. When the cartridge is pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
5. Close the cartridge compartment cover and control panel.
6. Press Start/Enter.
7. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount of remaining ink. Once you have put in a new cartridge, use it until it is completely exhausted.
Dec 22, 2010 | HP 1040 Plain Paper Inkjet Fax
Put new ink cartridge in Epson NX 110
I have a epson stylus NX110 Printer the ink cartridges will not stop so that i can put in new ones.I press the stop button but the ink cartridges will not stop onthe arrow so that i can put in all new ones.
Apr 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
Check print cartridge light blinks
pull the cartridges, with the power turned off swab w/ alchol swab the communication ports that the cartridges fit into, let dry then reinsert the cartridges and turn on the printer. The com ports get infiltrated with ink wont read the new cartridges.
Oct 12, 2009 | HP PSC 1315 All-In-One InkJet Printer
My printer doesn't not recognize that I just put in a new color cartridge
hi,
try to remove the new color cartridge, if you have a clean cloth, try to wipe to copper strip of the new cartridge. try to wipe the copper strip of the carrier where you put the color cartridge, BUT before doing that make sure that the printer's power cable is unplugged.
place the power cable after wiping the copper strip of the color cartridge carrier. then place the color cartridge. if still same. try the old cartridge. if the old one is recognized, it's your new cartridge fault. you need to contact dell to have the cartridge replaced. if you ordered it from dell.
Sep 30, 2009 | Dell 922 All-In-One InkJet Printer
I have a hp desk jet 5440 i put i a new tricolor
Make sure that your buying a new Tricolor as the same and Geniune too.
Only solution to this is put it properly inside your printer.
At first sometimes New Cartridge are being initial & calibrate by your printer before it works.
Power Off first your printer and put the cartridge inside. If the problem still exist then put back again your old cartridge and identify what is the problem occur before you put a new cartridge on it.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
Printer cannot find new black cartridge. Left cartridge missing.
The electronics are bad on your compatible and your printer can't recognize it's there. Return this cartridge and get your money back. The next cartridge you buy, ask if the electronics have been tested to be functional. I recommend refils from Cartridge World or Office Depot.
Apr 05, 2009 | Lexmark X4530 InkJet Printer
Fax saying no cartridge, but have just put new one in machine
That means that your fax machine is not recognising the cartridge. Either is not been put correctly or the cartridge suport is broken. Try with the old cartridge or with the new one use a bit of tape to old it against the contacts of suport cartridge. GOOD LUCK.
Nov 02, 2008 | Samsung SF-3200 Fax
New Ink Cartridge not working
first check the new cartridge tmake sure you took off the thin clear tape on the bottom of the cartridge. if you did then the cart. is falty and go back to store and exchange. please rate me. thanks
Sep 21, 2008 | HP DeskJet 810c InkJet Printer
Ink Cartridge Error
on your cartridges there is a chip that detects if the ink is low. The chip on your yellow cartridge is bad. You should return the cartridge for a new one(if you still have your receipt) or visit a Cartridge World in your area and they can put a new chip on for you
Aug 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
239 people viewed this question
Seeker5211
Seeker5211
