Question about Fuji FinePix J12 Digital Camera
Can you charge the camera through the computer via the USB lead
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 241 Answers
Short answer: No.
You need to put the battery in the charger to charge it.
Posted on Oct 12, 2009
5 Suggested Answers
Siestamagic
  • 6 Answers
SOURCE: the camera is not recognised
With XP you should be able to simply open up the "My Computer" icon on your desktop.
Under "My Computer" you should see a "Removable Disk".
Double Click on it, and then your should see "DCIM", double click on that and then you will see "100PENTX".
Double click on "100PENTX" and you will see all your pictures.
You can then copy those pictures to anywhere on your computer.
If this does not work for you, you can always use a card reader to download your pictures. Many later model computers have built-in SD card readers. If your computer does not have a slot for an SD card you can purchase a card reader, usually for under $20, at most major computer/electronics equipment retailers.
Posted on Sep 18, 2008
  • 102366 Answers
SOURCE: i cant charge my camera
In order to save size and weight, the camera does not include charging circuitry, leaving it in the cradle. This makes the camera smaller and lighter, at the expense of requiring a larger and heavier cradle.
Like most things in the world, the design was a compromise. Unfortunately, in this case it means that you can't charge the camera from a computer.
Posted on Jan 10, 2011
caroldon
  • 17130 Answers
SOURCE: My sanyo 720p camera is
Sometimes if the battery charge has gone below the threshold level then it will not charge the battery , So if you are able to JUMP start using an external charger from a bench power supply , it will take up the voltage and regain the level.
Once this is done reset battery and connect charger to charge. once charged, switch on and tap lightly to reset the lens mechanism that is struck up. Sometimes the lens can be pulled out with the hand while powering as it will free the mechanism. Blow some jet air to clear the lens gaps and free the movement.
Posted on Sep 20, 2011
  • 102366 Answers
SOURCE: how do i charge up tthe kiddizoom camera for my
The Kidizoom uses four standard AA batteries. You may use disposable alkalines or rechargeables. If you choose to use rechargeables, you much charge them using a separate charger. The Kidizoom is not a battery charger.
Posted on Oct 27, 2011
How to i get my windows xp to read sd card from bushnell trail camera
In general, connecting a digital camera to a computer is not the best way to work - and not the quickest. It is considered better practice to use an inexpensive Card Reader that you put your card into and that is connected to the computer via a USB lead - the lead must be a DATA lead - many used for charging are not suitable. Sorry cannot offer more help but your query is a bit vague.
Dec 26, 2014 | Bushnell Cameras
My nikon coolpix S220 wont charge. I had to buy another USB connector because my son lost his and it does not seem to recognize the camera at all and will not charge
The camera does not contain any charging circuitry and will not charge the battery when connected via the USB cable. In fact connecting via USB actually drains the battery faster because the camera has to communicate with the computer (even if only to say it has nothing to say).
The camera comes with a separate MH-63 charger. Take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet. Once the battery is charged, you can put it into the camera and try connecting it to the computer.
Better yet, don't connect it to the computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
Dec 14, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Can I charge a COOLPIX S3000 directly from a PC via the USB lead supplied?
Yes, as long as the computer's USB port puts out sufficient current. Not all USB ports do so. Make sure you're connected directly, not through a hub.
Dec 07, 2010 | Nikon Coolpix S3000 Digital Camera
My camera needs to be charged and i have lost the battery charger. so i put my camera on the usb cord and into the computer and tried to turn it on but it wont work.
You don't say what model camera it is, so I am going to have to do some guessing. If your battery charger normally charges the battery in the camera, then it probably will charge when connected to the computer by the USB lead. However, some cameras require the battery to be taken out and charged in an external charger. If that is the case with yours, then it probably won't charge by connecting to the computer.
It is normal for a camera connected to a computer via the USB lead to go into a kind of passive mode, just acting as an external disk drive so that files can be transferred, so not being able to turn the camera on while it is so connected might be normal. However, if you mean that you left it connected for awhile to charge up, but it wouldn't turn on after you disconnected it, then it is obvious that it cannot be charged up that way.
Oct 20, 2010 | Sanyo Cameras
When I plug in the usb lead to download the pics, the camera screen goes black as if off, i unplug the usb lead and the camera resumes normal function, do i need a new usb lead or is the problem something...
Consider NOT using the USB connection.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 15, 2010 | Vivitar ViviCam-X30 Digital Camera
Vivitar 8025 comes up msdc when i connect usb lead to my computer
It's supposed to do that, informing you that it's in mass storage mode. Once connected you control it from the computer, not the camera.
Nov 03, 2009 | Vivitar ViviCam 8025 Digital Camera
Can you trickle charge the Olympus FE-20 via the usb cable?
Very few cameras will charge through USB ports. This is only to connect to computer to access pictures. Your camera will not charge via USB. I suggest to many people that using cameras that take AA batteries is the best cameras to buy when traveling. Many camera owner fall victim to different voltage outlets when travelling.
Jul 02, 2009 | Olympus FE-20 Digital Camera
TRANSFERRING VIDEO FOOTAGE TO COMPUTER
you can access via USB only SD card on your camcoder.
The only way to transfer from the tape is via Firewire (IEE 1394) . You should have this port on your PC or laptop, if not you can buy external firewire card .
regards,
Konstantin
Aug 06, 2008 | Canon MV530i Mini DV Digital Camcorder
Reply
Hi there again,
I am assuming you are using XP OS.....
I have a couple of questions for you.
Try this.............
With computer on and camera NOT connected,
Please look at my computer,
1.What happens when you connect camera to usb lead then connect the lead to the computers usb port?
2,Would it upset you if we use another way of moving your photo and video files from camera to computer?
3.Does Memory card work in another device or computer?
Solution 1 =================================
If usb did not recongise the camera on the usb port then it will be a software and hardware reinstall ,
Remove usb lead from computer
Go to Add/Remove from you control panel.
Remove the cameras software.reboot.
restart install software first and reboot,
do not connect camera yet,WAIT.
once restarted add camera via usb
should be good to go.....
If it does continue to give you issues then consult the manufactuerer.
Solution 2 =================================
if the usb is connected to the camera via usb lead to usb port on the computer and you can see the cameras' drive info then its more than likely you will be able to open and use this file ,if so you should be able the move these files to your computer too.
Solution 3 =====================================
Explains itself really-Replace it if you need to.
Hope this sorts out your problem.
I beleive your card reader may be poked,
Uninstall and reinstall try again, replace if presists.
these solutions I have put forward have been proven to work in many situations so good luck and let us know the results thanks
Jul 16, 2008 | Computers & Internet
Fuji FinePix J12 Digital Camera Logo
689 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
