Question about Kenmore Washing Machines
Kenmore Series 80 top load washer Cold water trickles in. I have checked water line in and tiny screen where hose attaches. No problem. It is somewhere inside the machine that the flow is cut off. Any ideas? shuff11@comcast.net
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
I'd also see the following PDF on Whirlpool / Kenmore top load direct drive washers. It has a description of how they work and troubleshooting sections.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The problem sounds like one of the water control valves or switches, (assuming that you've verified that the hoses to the washer are turned on.
Posted on Oct 06, 2009
Kenmore HD Series 80 - hot water trickles in.
Pull the two screws at the bottom corners of the control panel. Pivot the panel up. Lever the two metal keepers underneath forward and up to remove them. Tilt the housing forward and pull it toward you to remove it. Make sure you unhook the lid switch wiring plug before you remove the housing.
Water inlet valve should all be one piece for hot and cold.
Nov 15, 2009 | Kenmore 26882 Top Load Washer
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Low water pressure on cold water cycle only. Need to know how to take out filter screen to clean. Lost water pressure during Hurricane Ike and have had this problem for a year. Haven't been able to find...
take off the cold water line from the valve on the wall. be sure and turn off the water first. the screen on the hose end may be plugged with rust or some debris.
Jun 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Cold water filling
There are filter screens where the supply hoses connect to the washer. On some brands there is a screen where the hose connects to the water valve at the wall. The screen is probably full of sediment.
Dec 14, 2008 | Kenmore 24622 Top Load Washer
Kenmore series 70 top load washer - cold water fill very slowly.
The screens in the line are clogged. There is usually a screen in the washer hose at the point where it is connected to the faucet as well as one by the water inlet valve. NEVER REMOVE THE SCREEN BY THE WATER VALVE. As for the one in the cold water fill hose, that can be cleaned or replaced.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
81 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
