Question about Fisher Dishwashers
Just installed fisher paykel model 88270 dishwasher, bottom drawer has no power,and top drawer does not fully drain. Cant find another power cord, is there a second one? Cant locate the manual.
reg501
  • 413 Answers
SOURCE: Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Posted on Jun 08, 2008
Master_Tech
  • 770 Answers
SOURCE: fisher paykel
Check your email
Posted on Jul 09, 2008
  • 784 Answers
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
  • 713 Answers
SOURCE: Fisher Paykel Dishwasher drawer not draining
F1 means that your machine has activated the flood switch. check the drain hose that is connected to the sink pipe is not blocked. remove clip holding hose to pipe, put end of hose into a bucket and turn on cycle. it should start draining straight away. if it does drain into bucket stop cycle and clean nossel of sink pipe with a small screwdriver. then refit hose and turn on cycle. if it doesnt drain into bucket please reply and i will guide you thru how to check to see if you roto motor is jammed or faulty.good luck
Posted on May 06, 2010
Testimonial: "I have not tried your suggestion,but will tonight...Thanks for the fast reply....let you know how it goes...Thanks "
Fisher paykel dishdrawer bottom drawer washes fine leaves water in top drawer
At some point the two drawers individual drain hoses are joined using a "Y' type connector. Check this, and everything beyond this point for restrictions or blockage. It sounds like the bottom drawer is pumping its drain water out normally, but some of that water is backing up to the upper drawer. This is an installation or plumbing problem that is external of the dishdrawers.
Jul 25, 2016 | Fisher and Paykel 23 in. DD-603SS Built-in...
MY FISHER /PAYKEL DISHWASHER DD603 DOES NOT HAVE A POWER CORD
Not sure why the power chord would have gone missing. I am assuming you may have an integrated model.
In any case you will have to take the bottom drawer out to gain access to the power filter board which is located at the base of the cabinet under the drawer.
To take out the bottom drawer follow instructions on page 7 of this installation manual.
http://www.fisherpaykel.com/vault/pdfs//pdf_installations/526609O_DDinstall_NZGBw.pdf
Make sure the drawer is not pulled too much out to avoid damage to wires and hoses underneath. Leave it on soft material on the floor. Next locate the power filter board at the base. It looks like the pcb in the attached parts diagram. The power cable is meant to go to the block connector on this pcb. Make sure you check connections carefully as mains voltages are involved. Put everything back.
http://www.searspartsdirect.com/partsdirect/part-number/Fisherpaykel-Parts/Dishwasher-Parts/525959P/0022/426/Model-DD60388445B/3068/0130000?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50042566&diagramPageId=00003&productTypeId=&searchModelNumber=DD60388445B&subCompDesc=Cabinet&brandDesc=FISHERPAYKEL&modelDesc=DISHWASHER&blt=11&shdMod=&keyId=15
Aug 05, 2014 | Fisher and Paykel Dishwashers
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
I have a small piece of plastic stuck in the drain hose of my fisher paykel top dish washer drawer. I have tried cable wire but it does not budge after about 3 inches. Is there a way to remove the bottom...
There are two pieces of drain house in a double drawer FP dishwasher. The one from top drawer, the one from bottom drawer which then merge into a U adapter before hoing as a single hose into the kitchen sink.
I don't think anything can be achieved by taking the bottom drawer out. If the obstruction is in the top drawer drain hose, you will have to take that out and turn it over and disengage the hose from the bottom of the sump. Your best bet is to refer to this install guide on removing the drawers. Refer page 7 step 2.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Use reverse method to put it back in. Make sure you keep a stool nearby to hold the drawer in place and not let it fall on the floor. The cables and hoses are very tight and need care when handling.
Jan 09, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
My fisher paykel DD S03SS dishwasher leaks from the top, & drain
The drawers should not leak unless there is a problem with the vacuum seal. Try cleaning the edges of the doors and operate. You should feel the vacuum is holding the doors. The seals could be faulty or vacuum system may be faulty.
About not draining completely - a possibility is the common drain hose after the U adapter being clogged. Remove the clamp and pass a flexible wire coat hanger towards the main drain pipe. If both drawers are not draining then it is unlikely the drain hose between the U clamp and the dishwasher is clogged. Also make sure the height of inlet water pipe and drain outlet is as specified in the installation manual
Nov 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher not draining well
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Comment posted on Feb 07, 2009 there should be tabs on the sides of the drawers at the sliders near the front of the machine.
Feb 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel 2 drawer unit
yes there is. It is just inside the white hoses that drain the system. 1 per drawer. They cost about $0.50 but are a real pain to get to. This flap will go bad in about 3-5 years and maybe sooner depending on the temp of the water used.
If the bottom flap goes bad, using the top drawer will drain into the bottom drawer.
Oct 12, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Dishwashers Logo
96 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
