Tv takes long time to switch on,at first it was only 1minute then up to 7mins then I thought it wouldn't come on at all then it came on after one day. I don't switch off. Television is only 2yrs old.
  • 83 Answers
This is a SMPS problum pls. sum capaciter replace. and this problum is solve [*] : pls tv set repareing with tech.
this problum is not majur don wery...
Posted on Oct 06, 2009
I have a regency E33 gas fireplace. after 6-7mins with fire on, fire and pilot both go out. any suggestions?
thermopile should show 600mv clean thermopile . clean pilot so its strong and blue . see how that goes, may need new thermopile .
Oct 20, 2017 | Heating & Cooling
Dishwash cycle takes too long (7mins) and dishes are extremely hot
The heated dry may be turned on. You can shorten the cycle by turning it off.
Apr 30, 2016 | Dishwashers
My washer gets unbalanced load with 7 minutes remaining
My bet is that the 7mins remaining point is exactly the commencement of the spin cycle. Does it do it every time or once in a while but always 7mins remaining? If it is once in a while then it is most likely just an improper loading problem. I need more info for a better diagnosis.
Jun 06, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
How to replace ignition switch on 2003 Olds Alero without removing dash
You don't have to remove the dash. Remove the radio and the instrument cluster. Then you can unhook the ignition switch bracket and work on it through the hole where the instrument cluster was
Dec 22, 2017 | 2003 Oldsmobile Alero
AC/Heater Blower Fan in 1990 LS400 works intermittently
Due to the age of your vehicle, the brushes in the fan motor are worn out. you will have to replace the fan motor, it is not serviceable.
May 30, 2017 | 2001 Lexus RX 300
Water flows continuosly for 1minute after switched off
You need to check all valves, one of them must be broken or too old.
Also the pressure is a little bit higher in there, but there is nothing to be afraid of.
CIAO
May 05, 2011 | Home
M having lg microwave model no-mc-8081alr .the problem is it takes more time in heating food
A simple safety teast.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Jan 18, 2011 | Microwave Ovens
My samsung jet s8000 switches on to the vodafone welcome page stays on this for about 1minute then turns off and does the same thing over and over without getting past the same welcome note, to access my...
My samsung jet s8000 switches on to the vodafone welcome page stays on this for about 1minute then turns off and does the same thing over and over without getting past the same welcome note, to access my phone, how can this be solved?????
Sep 14, 2010 | Samsung Jet S8000 Cell Phone
Overheating while idling,anytime your having to wait for 7mins.or so,suddenly the temp. gage will shoot up.
First thing that comes to mind is the cooling fans. Do the cooling fans come on? If not, 1st check the fuse for them, if blown replace (might blow then next one, then you are troubleshootng the fan circuit)
If the fuse is good, next step is the fan temperature switch. It will be located in the rediator. They are usually simple on/off switches so you should be able to short the two leads together and see if the fans come on.
If they do, replace the switch, if not, need to check the Fan relay.
Before replacing the relaay, I would take a volt meter and see if power is getting to the fans when it should be.
Peace
Mar 09, 2010 | 2003 Mini Cooper
Wont Crank
im thinking its the starter..i would take it out and brin it into like an autozone they test them for free..
Oct 24, 2008 | 1995 Jeep Grand Cherokee
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
