Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Runs 90 percent of the time Kenmore s/s 57262791
Runs most of the time night and day. All functions work. The refrig. is kept clean, nothing blocking anything except I may go nuts if this keeps-up.
Thank You
  • Anonymous Feb 11, 2008
    After a power outage our Kenmore refrigerator model # 106.53552201 does not turn off. It is keeping foods at correct temps. But does not seem to be cycling
    Problem Solver:
  • 17 Answers
Hello! panda1,
You are fine, if all is working, just leave it, and enjoy it.
Problelms that may arise: After adjustments, ice cream to soft; milk to warm, vegetables frozen, eggs frozen, temperature not controlled. Typical of this units.
Since this is a energy saving unit, It tends to use more energy being that the compressor is low rated. The evaporator fan runs a lot, the defrost cycles run multiple of times, noisy, grumbles, and can keep you awake, if one keeps a ear to it. Just forget it. Once in a while, look at the bottom of the freezer, move some items, look at the coil , in back, an see if there is any ice build up, Some is ok. It should be clean, clear after a defrost cycle. (See input from peyton32034) may be additionally useful.. Regards, fmauka
Posted on Dec 23, 2007
Have a GE side by side gsh22sgress unit. Child left freezer door open. Unit ran for days (in non-occupied appartment). Meat thawed. Cleaned unit inside with mild soapy mix. Unit runs but will not cool...
Open door let too much moisture into refrigerator. (The cooling coils, behind the back wall of the freezer compartment, are blocked with frost) If you unplug the refrig for a day or so it will work again, or you can take the back wall out from inside the freezer and melt the frost with a hair blower.
Aug 21, 2010 | GE GSH22SGRSS Side by Side Refrigerator
Every couple of days lots of water runs out on the floor.
It sounds like the defrost drain is clogged up. On some models there is a removeable white pull out cup located in the center back wall at the top in the refrigerator section. It is connected to a tube on the back of the refrigertor.If that is blocked water will be in the bottom under the crisper drawers.
Jun 10, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I have a whirlpool refrig-side by side-icemaker isn't working-I have only 50 volts at the icemaker-please advise
side by side? clear bin in freezer door? ru checking voltage at L and N with I/R flapper on left depressed and not blocking I/R beam? if so probably bad I/R board set (runs about $90 last i checked)
Aug 24, 2009 | Whirlpool Refrigerators
Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
May 12, 2009 | Refrigerators
Kenmore 50392
We were low on freon . This refrig's internal fans don't run until the proper temperature is reached
May 21, 2008 | Kenmore 53092 / 53094 Side by Side...
Kenmore Series 90 Washer
Aside from complete disassembly & cleaning it, try a hot wash on full with nothing in it except a bunch of bleach.
Jan 09, 2008 | Kenmore 15864/15862 Top Load Washer
GE side by side Refrig. with evaporator iced up solid.
Yes ill be glad to help John. Your refrigerant level is fine. Remove the motherboard axcess panel on rear of refrig. Locate 3 wire blue plastic connector on bottom of board. Wires are labeled Comp, Line, Def. Jump Line to Def and see if heater gets hot. If nothing happens than replace the heater. Let me know what happens.
Dec 04, 2007 | Kenmore 91365 Compact Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
193 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
tootsie mason
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
