Question about HP Computers & Internet
DVD/CD Burner ATAPI DVD DH16A6L SCSI Cd ROM Device When loading a CD/DVD for music or games the device just spins with no result.
HI.
Do you know where I can get a new driver.
I have problems with kode 19.
Thanks Karsten
Posted on Feb 17, 2010
HP PC does not recognise DVD player. Driver seEms to be OK but otherwise need an ATAPI DVD A DH1 SCSI cdrom device driver
remove from device manager and run found new hardware wizard let windows load compatable driver, or go to manufacturers website for drivers
Sep 07, 2013 | Pacific Digital (U30274) DVD±RW...
Cd rom wont open
Hi in front of the CD-ROM drive there should be a small pin size hole. Stick a pin in there to release the CD-ROM lock and it should open.
Jun 12, 2012 | Toshiba Samsung Slot Loading DVD+RW Slim...
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
Toshiba sd-r2312 driver corrupted . how can i update it ?
There is no such thing as a specific driver for cd/dvd readers/burners.
The operating system itself has suitable drivers for those devices.
However, it can be that the driver for the IDE/ATAPI-controllers is malfunctioning.
If you have chipset drivers for the mainboard, reinstall them. Otherwise remove in
the Device Manager the driver of the used IDE/ATAPI-controller and let the Device
Manager search for the Microsoft Windows drivers and install them.
Jun 12, 2011 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
I am unable to read any cd/dvd in my ATAPI DVD DH16A6L SCSI dvd ROM, checked in device manager there shows no problem.
Hi arunp_1995,
  • If you are unable to read any CD or DVD in your DVD -RAM drive , the this could be an indication of a bad lens , or a lens that required clearning.
  • I would suggest you to get a lens cleaner from the market and use it to clean the lens, by just inserting it in the drive , letting it spin for some time , and then removing it.
  • After you go through this lens cleaning process you can test your DVD-RAM drive , whether it's reading any disks or not , if yes then , problem is resolved, if no , then I would suggests you to connect the DVD-RAM to your friend's computer and check if it's working or reading your cds and dvds, if not then you need to get it replaced within the warranty period if the drive is still under warranty , or get a replacement, as it could be that repairing would cost you almost around the cost for a new drive.
May 13, 2011 | Computers & Internet
Atapi dvd ashila3l scsi cd rom device not working error code 19.....
Try removing the device and re-installing applicable software drivers
Sep 09, 2009 | HP Pavilion a705w PC Desktop
Drivers for Toshiba satellite A75-S226
here ya go
http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
Jun 25, 2009 | Toshiba Satellite A75-S226 Notebook
My DVD-RW has stopped burning.
Try uninstalling the burner using the Device manager and letting Windows reinstall the drivers on reboot.
Right click on My Computer then Properties > Hardware > Device Manager > click on the '+' next to DVD/CD ROM drives, right click on the drive and 'uninstall'. Reboot and Windows will re-install the drive.
Mar 15, 2009 | Pioneer DVR-112D DVD RW Dual Layer Burner
Toshiba DVD ROM SD M1302 driver
If you are using Windows 98, 98SE, ME, 2000, NT or XP, and have an ATAPI/IDE CD/DVD drive, there is no driver needed (see Toshiba statement I have posted below). Under no circumstances, if DVD is properly installed and functional, will you need ANY driver!
If your DVD drive is a SCSI drive, then it may need drivers specific to the SCSI card you have installed (see the specs/manual or website for your card). You may also need the Adaptec SCSI setup, available at this address:
http://www.adaptec.com/worldwide/support/suppbyproduct.jsp?sess=no&language=English+US&cat=%2FTechnology%2FSCSI+Software&fromPage=driverindex
or use this address if you have a LOGIC based SCSI card or device:
http://www.lsilogic.com/
Now, if you meet the criteria for the first paragraph I wrote, and your PC does not load the driver automatically (after a reboot or two) then you have a PHYSICAL or HARDWARE problem. Either the DVD drive is improperly cabled, improperly installed or defective.
Those are all your options. See below, from Toshiba website
good luck
http://sdd.toshiba.com/main.aspx?Path=ServicesSupport/DeviceDrivers
ATAPI CD-ROM and DVD Drivers
Toshiba's CD-ROM and DVD-ROM drives do not require any unique device drivers for Windows '95/'98/2000/XP/NT.
After installing your drive and re-booting, your system should recognize your CD-ROM or DVD-ROM. Win '95/'98/2000/XP/NT Operating Systems support all Toshiba ATAPI CD-ROM and DVD-ROM drives natively.
DOS/Windows 3.x Device Drivers
This device driver is to be used with DOS/Windows 3.x operating systems. Do not use this driver with Windows '95, Windows '98, XP or Windows 2000 unless you are going to use your system in the REAL or MS-DOS Modes. Device drivers for Windows '95, Windows '98, Windows 2000, XP, OS/2, and NT operating systems are provided with the installation or setup software of each operating system.
DOS ATAPI Interface Driver
If you prefer using DOS click the link below to download a MS-DOS ATAPI interface driver.
atapi.exe
SCSI CD-ROM and DVD Drivers
SCSI interface drivers are written for the SCSI card you are using in your system, by the SCSI card manufacturer. They are not specific to your Toshiba drive and are not provided by Toshiba. If during installation Windows can not find the correct SCSI software driver for your SCSI card and you do not have the software driver that came with your SCSI card, contact your SCSI host adapter manufacturer.
Adaptec SCSI Drivers
LSI Logic (Symbios) SCSI Drivers
DVD Viewing Software
Toshibas DVD drives require a third party software to be installed in your system to enable you to view DVD movies. If you purchased your drive as part of a kit, the software may have been included. The links below will provide some possible solutions should you not have this type of software.
Nero6 (Toshiba recommends)
Toshiba does not recommend nor endorse any of the following manufacturers software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
DirectDVD
Cyberlink PowerDVD
WinDVD
Media Burning Software
Toshiba's recordable drives require third party software to be installed in your system to enable you to burn media. If you purchased your drive as part of a kit, the software may have been included. The link below will provide some possible solutions should you not have this type of software.
Toshiba does not recommend nor endorse any of the following manufactures software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
NTI CD & DVD Maker
Gear DVD & CD-RW
Roxio Toast (Macintosh)
Easy CD Creator
Stomp Clinkn Burn Pro
Feb 24, 2008 | Computers & Internet
Computers & Internet Logo
2,584 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
