Question about Garmin nuvi 205W GPS Receiver
Some minor streets don't appear on screen until I'm almost on them or past them. Is there a setting change this?
  • 37 Answers
Try hitting the plus (+) sign to zoom in on the map.
Posted on Oct 06, 2009
Blue on the screen of the tv
Try to initialize it!
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight "MEMORY INTI", arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Jun 23, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
Google maps: street views keep going to a split screen with street on top and satellite on bottom. Also street views in full screen mode disappear after a second and the split screen mode reappears.Very...
When you go into the split screen, and you don't want to be there, just click the little arrow in the lower right hand corner (the arrow pointing down and to the right). This will reduce the bottom map portion into a small overview box in the lower right portion of the screen. It only takes a second to get out of the split screen that way. To get back into split screen, click the arrow in the upper left corner of the overview box (the arrow pointing up and to the right).
Aug 15, 2011 | Computers & Internet
Don't know how to set the date except by winding the time dial repeatedly past 12 to get to present date--must be an easier way
I presume that you are winding the watch 24 hours to change the date.
You can shorten the time it takes to change the dates in the following manner:-
Wind the watch until the date changes, then turn it back until it passes 12 again and then turn it forward. Each time it passes 12 the date should increase by a day.
You may have to experiment to find how far past 12 in both directions to get the date to change.
May 12, 2011 | Baume Et Mercier Baume & Mercier Classima...
The printer screen display is in chinese or other asian language therefore want to change it back to english How do i do that?
Incorrect language appears on the display
These are possible solutions. Try one of the following:
Change the language selection during initial setup
After you select a language, Language appears again on the display. To change the selection:
1 Press or repeatedly until the language you want appears on the display.
2 Press to save.
Select a different language after initial setup
1 From the control panel, press or repeatedly to choose Setup.
2 Press .
3 Press or repeatedly to choose Change Printer Default Settings.
4 Press .
5 Press or repeatedly to choose Language.
6 Press .
7 Press or repeatedly until the language you want appears on the display.
8 Press to save and exit.
Note: If you cannot understand the language on the display, see "Resetting the printer to factory default settings" on page 57.
Manual:
http://images.lexmark.com/publications/pdfs/2007/4800/v4924668_en.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 17, 2010 | Lexmark X4875 InkJet Printer
Silicon scientific atomic projection clock did no reset for daylight saving. Help
I have one of these, and look for the manual on the 'Net every time DST changes, and eventually figure it out. Here's how: (1) Hold down the ALM/SET button until you get past the alarm setting and you see 24H or 12H. (2) Step through the settings by pushing the ALM/SET button, changing each as desired by pressing the +/CYCLE button. Eventually you'll wind up with the time zone indication flashing (it's really tiny, and appears just below the time indication). Press the +/CYCLE until you get to the desired time zone. (3) After the screen quits flashing, press the -/DST button to get the desired setting. I hope this helps, and that I can find this post again next time change!
May 19, 2010 | Watches
Xxl 530s spoken street names
Not all sound files speak out the street names. So, in a way, it is your set up that needs to be changed. It is is not a wrong information. If you want, street names spoken, you need to select a voice that ends with computer. For example, the voice file selection: Simon, English UK, Computer will speak street names. But the voice file, Bonnie, English US will not speak Street names. Dave, English US, computer will give you street names but Lori or Mandy, English US will not. Procedure to get the street names spoken: Tap on main screen. Tap on change preferences. Tap on arrow. Tap on change voices. Tap (select) a voice that ends with computer. Tap select. Tap done till you reach the main screen.
Apr 11, 2010 | Tomtom ONE XL GPS
How do i load favorites into my tomtom 720.please set out steps
Depending on the operating system of your TomTom you should be able to tap the screen then tap the forward arrow until you see "add favorite". Tap "add favorite" then tap "address", then tap "street and house number". Type in the city. This will bring up a screen with several cities on it. Select the city you want, then type in the street name. the next screen will let you put the street number in. tap done. Tap OK on the next screen.
Nov 15, 2009 | Tomtom GO GPS Receiver
Screeen went blank after changing resolution and hz appeared
refresh set to high boot safe mode change settings.
this has worked for me and XP.
Don
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Change Clock - Logitech Pure-Fi Elite
hold the src button left of power along with button to the right power.a model number will appear once it does let it disappear and the unit will go into reset. set the language, 12/hr, 24hr etc and the time. :)
Dec 13, 2008 | Logitech Pure-Fi Elite High Performance...
Nokia 6110 navigator
when i press the navigate button it searches for a few seconds and then it stops and says "street not digitised". the phone's navigator worked until friday then it stopped. i don't know if someone maybe played with my phone and changed my settings. please any one?
Aug 24, 2008 | Nokia 6110 Cellular Phone
Garmin nuvi 205W GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
