Question about McCulloch MC1235 Handheld Steam Cleaner
It is leaking and is not making steam. - McCulloch MC1235 Handheld Steam Cleaner
HOSE LEAKING WHEN USING TOOLS OTHER OSE STUTTERING AND WON'T STEAM HAVE USED KALSTOP
on further inspection the hose that is leaking appears to have a big 2 cm short faill like its been pushed into itslef thats hwy its leaking its not connecting correctly and the other hose i think a spring may have gone on the trigger itself. as when press steam come out and then won't its like the button you press to swith it off is shyt off and no steam.
Nov 20, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
My shark steam mop is leaking water where you attach the mop head. I tried taking it apart and even cleaning it with vinegar but it i still leaking. What can I do?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
May 10, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The water is leaking out of the steamer it is getting not but leaking out
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Nov 02, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Makes steam. Leaks where pad goes into pad attachment. Pad doesn't get hot steam...just water but the pad doesn't really get wet but the floor does.
heatman101
Oct 10, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hoover steam vac leak from the bottom when tank has water in it when not running but tank is not leaking
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Nov 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac clean water reservoir leaking.
take the clean water tank out and look on the bottom for a fitting that screws on make sure its tight.also inside of that fitting trhere should be a washer or an oring to keep it from leaking.if thats not the problem then your pump mightbe leaking.for that i would take it to a vacuum repairman.i hope i have been of some help.please leave feedback
Apr 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
McCulloch MC1235 Handheld Steam Cleaner Logo
24 people viewed this question
Top McCulloch Vacuums Experts
JoeVacs
Are you a McCulloch Vacuum Expert? Answer questions, earn points and help others
