Question about Teac GF-650 Turntable
Turntable runs a bit too fast, on any setting i put it on, and i dont know what to do about it. its making everything start to sound like the chipmunks. thanks for the help! Sierra
  • brumittduren Oct 06, 2009
    unfortunately it isnt the settings on the switch, because for each speed it has a proportionately faster rate. like a 45 is playing a little bit faster, say 10%, but when i go to the 35 setting, its the same 10% faster.. (btw im making up the numbers because i havent timed the rotations yet)i feel like it could be the belt is stretch a little, or the motor is doing something it isnt supposed to. i will definitely try and find a repair shop in the meantime.
    thank you
    Scholar:
  • 92 Answers
LOL, The Chipmunks rock!..j/k
Sounds your player isn't reconizing your settings, therefore the switch that controls them could be shot.
Firstly consult the troubleshooting section of your manual
If you have have no manual to reference, check this site for a downloadable one.
If still no, then visit the Teac home page and follow the support/troubleshooting/customer service links there.
There also you will find listings for any authorized repair shops in your area where you can have it looked at and a new switch installed, should that indeed be the issue.
Conversely to that, call the toll free number you will find in your manual or on their website for assistance.
Wishing you luck and... no more Chipmunks...
Posted on Oct 06, 2009
Just got this and set it up. Sound is high pitched, sounds like alvin and the chipmunks are singing.
It sounds like it's running too fast! If it is a belt drive model you must have got it set up wrong.
Sep 16, 2011 | Crosley Cr6005a Turntable
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
Teac turntable plays too fast
This sounds like a motor speed control problem. It could be either the motor itself or an electronic fault. So unless you know a bit about electronics and know how to use a soldering iron etc, then the answer to your question is no.
Oct 23, 2009 | Teac GF-650 Turntable
Tonearm Weight, Good Replacement Stylus, Gain level
Most good turntables will track with weights between 1.25 and 1.5 grams. Any more than that and you are putting alot of pressure on the needle. Experiment a bit and make sure that the needle tracks well and that the sound is good. The less weight you use, the longer the needle will last and the less wear on the record.
Dan
Aug 11, 2009 | Numark ttUSB Turntable
Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
Nov 07, 2008 | ION Audio iTTUSB Turntable
Panasonic automatic turntable model sl-hm42
I'm having a similar issue - except my panasonic sl-hm42 platter is moving too slow on 33 1/3 settings (don't have any 45's to try). It's a DC model, so I would think there would be some kind of pitch control settings or screws somewhere on it but I can't seem to find them.
Does anyone know if it's possible to adjust the pitch on this model turntable? Thank you!
Oct 25, 2008 | Panasonic Technics SL-DZ1200 Turntable
I have a Denon 300f that works fine but run a bit fast so the music sounds really off...anything I can do to slow it down?
I was putting the belt around the wrong part...it needed to go on the bottom of the turntable itself then be attached to the belt drive.
Jul 17, 2008 | Denon Audio Players & Recorders
My tunrtable spins backwards :S
these motors are quite cheap. You can open it up yourself and see if any resistors are burned up. If not, contact numark parts dept and order new motor. quite easy to install.
Dec 06, 2007 | Numark BATTLE PAK v.4 Turntable
Teac GF-650 Turntable Logo
460 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
