Question about Garden
I have a snowblower which i believe was built by Murray, 8 hp engine 6 forward speeds and 2 reverse. Took the rear cover off so see if i could find out what is causinf the issue. The way it works is a round plate spins from the engine and when you pull on the lever to engage the tires the plate is pushed up to come in contact with a rubber wheel. Now in reverse the wheels move and the snow blower baxks up just fine, but in any of the forward gears the plate just spins on the interan rubber wheel when ever there is the slightest about of reistance, if i take the unit off the ground the wheels move just fine. I am assuming i have to replace either the plate or the internal wheel but am unable to find parts. Any thoughts would be helpful.
    President:
  • 1,129 Answers
The rubber wheel probably has a sheer pin or key way that has broken remove the ruubber wheel inspect and replace broken key or sheer pin in shaft.
Posted on Dec 09, 2009
I want a manual for a Murray ultra 24" 8 hp snowblower
I believe this is what you're looking for.
https://lawn-garden.needmanual.com/murray-walk-behind-1695539-8-0-24-inch-dual-stage-snow-blower-owners-manual.html
Apr 03, 2017 | HP Garden
Troy built storm 2890 snowblower slow in reverse
There is an inspection pan on bottom of snow blower remove the 2 or 4 bolts and drop pan
inside you will see an aluminum wheel (drive wheel) also a rubber faced wheel whitch runs on the aluminum wheel at a right angle (like a needle runs on a record on a record player.
Clean plate and rubber wheel using brake clean to degrease surface .
Also there is an adjustment to move the rubber wheel farther to the left for more reverse speed but in doing that you might lose top speed forward.
Mar 02, 2015 | Garden
Noma snowblower transmission is backwards, put in forward it goes backwards and so on
Dear Richard,
Your direction with the gears appears to be 180 degrees out. You may also consider flipping the entire shaft assembly. You. Knowing this assembly is put together correctly.
At this you tube link you will find information to watch for your Norma. The side bar with a catolgue has your answers.
Here is a forum and a blog that may help when the order is corrected
Small Engines Lawn Mowers etc Noma Murray Snowblower question
Craftsman Murray Snow Blower Belt and Friction Wheel Replacement
Dec 09, 2014 | Garden
Snowblower wont engage forward or reverse
Howdie ther is Clutch under the bottom of it that needs to be replaced take the cover off and you will see it
Jan 30, 2014 | Craftsman Snow Blower / Snowblower Bottom...
I have a 1999 Tecumsah Lawnboy 824E 8.0hp, model 28232, snowblower. Last snow the forward and reverse stopped working. The snowblower runs but the wheels locked up. I was able to get the forward and...
Here is a link that may help,ihttp://www.partstree.com/parts/?lc=lawn_boy&mn=28232. Adjust and lube the cables for drive engagement, and the other cables and Hiem joints. This usually will rectify the problem.
Apr 16, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
2002 kia sedona number 1cylinder ft head or rear 3.5 ltr
on all v-6 v-8 engines the number one cyl is the furthest forward valve cover. one valve cover will be built closer to the front of the engine this is always # 1 cyl firewall side is 1,3,5,
radiator side of engine is # 2,4,6, cyl. so number 1 is the rear forward cyl
Aug 31, 2012 | Kia Sedona Cars & Trucks
While useing my mower today, I stoped to put it in reverse. after backing up, it would not go forward again. It will not go in reverse either. With the clutch peddle not pressed in, You can push the mower...
there is a drive belt that is either broken or off inside the tractors frame. You will need to remove the cover, between the seat and steering will, where you shift, I believe it is like four bolts/screws. You can purchase a new belt at an home improvement, wally world, a parts store. Hope this helps Tim
Oct 29, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My Poulan 42-Inch 17.5 hp Briggs and Stratton Engine with 6 speed will not move. The motor runs fine but when I go to put it into gear the mower will not move whether it be in reverse or any of the forward...
Assuming you have checked the main drive belt and it is snug, I think you have a problem with the hydrostatic drive. These are replaced with used or new, ain't cheap either way.
Jul 15, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Where's the number one cylinder on a ford f-150 truck?
Select your Engine for Ford Pick-Ups/Expedition/Navigator 1997-2000...
Ford 4.2L Engine Firing order: 1-4-2-5-3-6 Distributorless ignition system
Ford 4.6L Engine Firing order: 1-3-7-2-6-5-4-8 Distributorless ignition system
Ford 5.4L Engine Firing order: 1-3-7-2-6-5-4-8 Distributorless ignition system (one coil on each cylinder)
Ford 5.8L Engine Firing order: 1-3-7-2-6-5-4-8 Distributor rotation: Counterclockwise
Ford 6.8L Engine Firing order: 1-6-5-10-2-7-3-8-4-9 Distributorless ignition system (one coil on each cylinder)
7.3L Diesel engine injection order: 1-2-7-3-4-5-6-8
Ford 7.5L Engine Firing order: 1-5-4-2-6-3-7-8 Distributor rotation: Counterclockwise
I hope help you (remember rated this help) good luck.
Sep 14, 2009 | 2000 Ford F150 Flareside SuperCab
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
