Question about Canon Office Equipment & Supplies
Detached coil The paper tray would not come out, I pulled to hard and a small square plastic part broke off and the strong 2-part coil was loose. Cannot get paper to stay down as tray lifts it up...
    President:
  • Canon Master
  • 990 Answers
Hello sir; I don't know how can I tell you over the phone, the best way to solve this problem is replace the tray.
Posted on Oct 06, 2009
Sharp mx m363n
Hey there,
I have had this problem with an HP printer. The problem was due to a small plastic arm which was attached to the paper load sensor for the printer. It had become detached from its seating, and printer could not fully detect the load in other trays, so it always went to the default tray. Try opening all the compartments you can on the printer and look for a small lever which appears to be just dangling. Place the loose end back in its seating, which should be obvious to see when you find it. Hopefully it has not broken off. Good Luck!
Oct 03, 2013 | Office Equipment & Supplies
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
Clean a KX-P7100 printer
The paper jam in theKX-P7100 is usually due to the paper tray.
If you pull the paper tray out you'll notice a black piece of plastic (located at the most front) with a cork like material in the middle. Try pushing down on this piece of plastic a few times. If it does not pop up immediately the grease that Panasonic used has become "sticky". The piece of plastic is removed by turning the tray upside down and pushing on the small plastic tabs that hold the black piece of plastic in. Be careful to not loose the spring that is located under the black piece of plastic or break the plastic tabs that hold it in place. Once you get the black piece of plastic out, clean it with que tips and clean the area it slides up and down in. Make sure to remove all the "sticky" grease. Once you get it clean, don't forget to stretch the spring to one more inch. the spring quality is awful at tensile strength. Then place the spring back in its place and push the black piece of plastic back in its place. You can add some light oil to the black plastic to make it slide better. After it is reassembled try pushing down on the black piece of plastic a few times. It should spring up almost immediately. This should take care of the jams that you are experiencing.
In addition, you may have to stretch the 2 big springs under the metal plate in the paper tray to one more inch. To access them, you'll have to unscrew the 3 philips screws under the tray (take a picture before :-)), take away the 2 blue pieces and take out the metal plate.
Now I'm able to print from the media tray without any problem :-).
Hope this helps!
Dec 09, 2012 | Panasonic KX-P7100 Laser Printer
Xerox workcentre pro 90 says tray 2 not available, reset software and hardware but wont print from tray 2, paper size 11x17, any ideas
Take the paper tray out as follows: open the front door, pull the tray out as far as it goes. On the side rails there is a hole and if you look into the hole there is a stopper. Turn this stopper a little by a small screw driver or similar and simultaneously pull the tray out on the other side, then the remaining side one by one.
On the back side of the tray there is a sector plastic gear and a smaller one. Sometimes they lose teeth because paperr stack is very heavy and thy are made of plastic.
Another cause may be improperly installed feed rollers.They must be installed right way round. When paper stack raises the feed rollers actuate a fork which, in turn, actuates a plastic flag which in turn blocks a sensor in the inside back wall if the copier/printer. Everything is fu**ing plastic and breaks easily.
Aug 24, 2010 | Xerox WorkCentre Pro 90 Copier
Paper is getting jammed when printing is commenced , I am using cl-41 color and pg-40 black cartridges
paper can jam up if paper is too loose in tray dosnt go in square to the printer, too much in tray,,the roller not pulling in the paper evenly paper damp and sticking together
Jul 06, 2010 | Canon PIXMA iP1300 Printer
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
Can not remove waste tray. Is there a any other
The waste tray is parallel to the maintenance (cleaning) tray. If you miss the 30 second window (seriously) to remove the waste tray the printer will lock the tray by dropping a small plastic arm (which can break if you pull on it too hard). However, the small plastic arm is accessible from the maintenance tray slot. If you look inside the maintenance tray slot (the left slot) on the right wall roughly 1 1/2 inches in you will see a tiny white square piece that you can easily reach with your index finger. Just apply light pressure to the top of that white piece and it will lift the plastic stop that is holding in the waste tray. If there is any resistance when you try to push down on that white plastic piece just try either gently pushing or pulling the waste tray to ensure that the white locking piece isn't caught on the tray.
Dec 15, 2009 | Xerox Phaser 8500/DN Printer
I broke the paper tray on my Ricoh AP 2000; need a replacement
Everything is repairable! Between epoxy, super glue, model glue (works better on the plastics it's designed for) and Duct Tape!?!? Yankee Engineering!!, Come on. :^D
But to answer your question: eBay
Aug 24, 2009 | Ricoh Aficio AP2000 Laser Printer
Laserjet 4700 Tray 2 stuck will not pull out.
You possiblely have something loose in the tray or something broke. Find something metal and thin, like a hack saw blade, and stick it through the slot between the drawer and printer and see if you can feel the obstruction, and if so try to move it out of the way. Something is catching on the printer frame and drawer.
Feb 27, 2009 | HP LaserJet 4700 Printer
Lexmark Optra T612
The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
Aug 04, 2008 | Lexmark Optra T612n Laser Printer
old marine
old marine
