Question about Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MCG8000AW upper cabinet acts crazy now won't heat
My Maytag Neptune MCG8000AW upper cabinet seemed to be getting hotter than usual when drying. Shortly after, the heater apparently didn't shut completely down after a load was finished, and I noticed the inside of the cabinet was still warm after an extended time (at least a day). Now the upper cabinet won't heat at all.
Today I ran diagnostics: the logic board tested "pass", the keypad tested OK, sub system check was all OK except the upper dryer heater temp would not go above 81. I unplugged the dryer for a period of time, no difference. Restored the factory default settings, no difference. The machine is not giving any error codes and nothing is showing up on the diagnostic code list. There are no problems with the blower or the water valve.
  • 2 more comments
  • amanda847 Oct 06, 2009
    There's no problem at the outlet because everything works fine except for the heat in the top cabinet.
    Could this be a thermostat problem? The dryer initially got too hot, then ran at low heat when it should have been completely off, and now won't heat at all. The blower is working OK.
    I've seen a diagram with instructions for accessing what seems to be the lower cabinet heater assembly, but nothing similar for the upper cabinet, other than the steamer heater. Does the steamer heater also heat the upper cabinet, or is it only for heating up water to make steam?
    Only the lower cabinet of the dryer is gas. The upper cabinet (which is the part I'm having trouble with) is electric.
  • amanda847 Oct 07, 2009
    Ok, opened up the dryer and tested the thermistor for the upper cabinet, it's blown. Shorted the connection and the heater is definitely working. Is there anything else that should be tested/replaced along with the thermistor?
    Thanks! It feels great to be able to fix the problem myself.
    President:
  • 1,723 Answers
The 'thermal fuse' probably blew during the extended heating of the dryer. It will need to be replaced. You will have to open up the dryer and it's down by the motor. Here is a picture of the fuse:
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Oct 06, 2009
  • Craig Butler
    Craig Butler Oct 07, 2009
    No, that's it. Change it out and you're good to go! Nice job there, think how much it could have cost you?
  • 3,741 Answers
yes its the problem of thermostat in the unit its got short. Safety thermostats are usually always found on the heating element housing or cage assembly. dryer thermostats are an single pole, double throw style and can usually be identified by a third wire terminal ( often smaller ) mounted towards the top of the thermostat housing . ---------- Gas dryer with no heat: The parts that I have pointed out with the arrows are the parts that you will need to check with an ohm meter if the dryer is not heating. First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arc where they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
Does the igniter get red and stay red, or does it get red, you hear a click and it goes off, then a minute later its gets red again?....if so you possibly have a bad set of coil valves. If the igniter gets red and stays red constantly then its the flame switch that is bad and maybe welded closed.
--------- thanks.this will help.please do rate the solution.thank you for using fixya.keep updated.
    Brigadier General:
  • 3,513 Answers
Hi
You have to determine if the heating element needs replacing, for that you have to check for 240V at the element connections when the dryer is running. You have to be carefull,If there IS 240V, replace the element. If not, then you will have to do continuity checks on every component in the heating circuit. First though, make sure that you have 240V at the outlet - it might just be the outlet or breaker.
Thanks for contacting Fixya.com
I have a maytage neptune mcg8000aww, the machine is plugged in but there seems to be no power to it.
bad thermal shut off fuse , this burns out usually due to overheating, so just replacing it wont suffice? check ur venting and cycling thermostat also.
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
The upper cabinet of our Maytag Neptune MCG8000AW Gas Dryer has always "dried" my dress shirts to come out without wrinkles. Now it seems to have power and light but it is not producing any heat
Most of the time a "no heat" condition on a gas dryer is due to one of two things: burned out ignitor Appliance Parts and Accessories Repair Appliance Parts Discount Parts... OR it could be a thermal limit switch that has failed which are easily replaced with this kit Dryer Thermostat Kit At one time, there was a TSB (Technical Service Bulletin) out on this particular dryer that referred to a change that was made to the electronic control board eliminating the need for an external heater relay in December 2002 (Series 61). The new control board is supposed to work in place of all previous electronic control boards. Good luck.
Mar 12, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer won't heat
check to see if it heats up for the first 2 minutes if it does then i would replace the coils on the valve if not check the thermal fuse on the blower housing
Feb 24, 2013 | Maytag Neptune MCG8000AW Gas Dryer
I need to take off the lower front of the dryer unit to gain access to the igniter
Just remove the control panel. The screws are accessible from the drying cabinet. There will be 5 screws holding the bottom panel in place from the top. It tilts out then up off the clips.
Sep 08, 2010 | Maytag Neptune MCG8000AW Gas Dryer
My Neptune MCG8000AWW Dryer isnt heating up. How do I get to the ignitor??? Does the front come off or is it through the back of the unit.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 24, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Does not heat
Bad ignitor will cause no heat. Do you have ignitor glow?
Jun 21, 2010 | Maytag Neptune MCG8000AW Gas Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
461 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
