Question about Kenmore Elite 45986 Front Load Washer
F11 CODE on 110.45966400
I have replaced the motor control board but still have the problem. I think that the CCU board needs to be replace but what I need to know is the Electonic control board and the CCu board the same thing?
    President:
  • 1,653 Answers
The ECU is often referred to as the CCU. F11 is Serial Communication Error Between MCU and CCU - Disconnect power and unplug unit. Check wire harness connections to the motor, Motor Control Unit (MCU), and Central Control Unit (CCU). Check the drive system for any worm or failed components and reconnect power and plug unit in. Verify CCU is working by performing diagnostic test or any cycle. Check MCU by looking for operations of the drive motor and check drive motor for powered rotations. Also check the motor and wire harness. Replace defective part
Posted on Oct 06, 2009
F11 error - Whirlpool Duet washer
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2P3BOEFKI
you'll need to call someone in on this one,boards are very expensive and like it says it names both the ccu and mcu boards or the motor,if you call say whirlpool they might give you the part but you pay for labor and they will have the boards on the truck,the guy will replace one board at a time to see what one is bad,not like the older machines that you can check the parts with a meter.good luck
Mar 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
R11 error message
F/11 Serial Communication Error
globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
My wife loved the Whirlpool Duet washing machine when she first got it, but now I think she would be happy to push it off of a cliff. We haven't even had it 2 years and about once a week it stops working in mid cycle. It beeps, flashes F11 error code, stays locked and there is no way to unlock it to get the wet clothes out. We have tried unplugging it to reset it. Sometimes this method works but sometimes it doesn't and when that happens, the wet clothes are stuck inside the machine...sometimes overnight. We've called the repairman a couple of times ($50 a pop) to unlock the door and get it started again. The repairman told me this is an extremely common problem with the Whirlpool Duets. Some of the computer units must have been faulty. It's hit or miss for those of you who are thinking about purchasing this and the problems usually start after the first year or two.
TIP: If your machine displays this error code and it is within the time period of your warranty, get the CCU replaced ASAP. Don't let Whirlpool stall while your warranty runs out. You should have a 1 or 2 year warranty which covers electronics.
We have to buy a new door lock and have the CCU replaced. The problem is that the new part is not guaranteed...not even for one day so if we get another faulty unit, we'll have the same problems again after a year of use.
Starting to see these fault codes pop up in these otherwise fine machines. The F/11 code is just a generic code generated when there’s a communications error between the two main control boards in the washer. These two boards are the Motor Control Unit (MCU) and the Central Control Unit (CCU).
A common problem is the wiring harness jiggling loose; remove and reseat it and that usually fixes it. If not, then you’re looking at spending some money on control boards. Yes, I said boards, plural. The really sucky part is that there’s no way to definitively and conclusively prove which board, the MCU or the CCU, is at fault so, unfortunately, that only leaves trial and error.
Here is service manual for whirlpool duet GHW9100 tis close
Nov 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
What do the following codes mean: F70 and F71. My washer is a Kenmore Elite HE5t. Thank you
The F70&F71 mean basically the same thing
F70 means the main control board is not communicating with the cycle selector/touch pad control
F71 means the cycle selector/touch pad controlis not communicating with the main control board
What needs to be checked is the wires between the main control(CCU) and the selector(user interface) for good tight connections
If all connections are good and tight the CCU has to be replaced IF the drum will rotate under power from the motor
OR if the drum will NOT rotate under power of the motor the USER INTERFACE needs to be replaced
Gene
Aug 18, 2011 | Kenmore Washing Machines
Washer keeps giving a F11 error and won't reset
this is what F11 means
"F/11" Serial Communication Error
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check MCU
  • Check CCU
  • Check Motor
there's a possibility you may need to repace the motor controller(ccu) but most likely you have a bad connection between the main control(the front board) and the CCU(the board inside the washer). you need to unplug washer and get iside to check wire connections. good luck to you.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is F11 code, how can it be fixed
The F11 code is saying that there's no communication between the motor (motor control board) and the CCU. Both the MCB and CCU are just big circuit boards. Most often the F11 shows-up with the FdL code (door lock) in either case the problem is cold solder joints on the CCU at the points where the relays and spade connectors are supposed to be connected to the board. The CCU is located in the machine at the top, back, You'll need to remove the circuit board and have those solder joints redone. It's easier to unplug all the connectors to the CCU then take out the whole unit and then take out the circuit board at the table wile you're cursing whirlpool. If you're not to handy with a soldering gun you may want to print off this response and take the board to a good appliance repair shop. Good luck.
Dec 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have a kenmore 4 t and i am getting f11 code what can i do
The F11 code means that the computer control board (CCU) is not communitcatind with the motor control board (MCU). I have tried manually fixing this problems a number of time by unplugging and plugging in all of the terminal on the entire machine, and its worked about 50% of the time. First try this and if it doesnt work you will need to replace the CCU. You can order it at, http://www.reliableparts.com/ using your model number.
Please rate my solution if it was helpful to you.
Thanks, Repairman45
Dec 02, 2010 | Kenmore HE2 Plus Front Load Washer
Error code F11
F11= Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. The board needs to be replaced. Here is a link to it.
http://www.repairclinic.com/PartDetail/Circuit-Board-or-Timer/1059575
Nov 25, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washer displays an F11 error code. I replaced the MCU but still the F11 code. Wire harness is good.
Hi.
It is probably the CCU (main control). Wiring harness, motor and drive train must be checked before replacing the CCU.
Here full troubleshooting for F11.
F11 is communication error between CCU (main control unit) and MCU (motor control unit - additional control module connected to motor and to CCU, located in a sealed box inside the washer).
This usually means that either CCU or MCU is defective. In some case the connectors or the wiring harness connecting the two modules is the problem.
The tech sheet says:
F11:Serial Communication Error
Solution:
* Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
The wiring harness is tested using a multimeter to ensure that there is continuity between the MCU and CCU connectors. If a single wire is good it will read zero Ohms (closed) from contact to contact.
Motor is tested reading Ohms, it must be read about 6 Ohms on three different pairs of contacts.
Drive system in motor is checked observing if any of the parts are broken.
MCU and CCU are tested reading volts during operation and testing at component level. The testing must be done by a tech. Check CCU to see if there is any sign of failure (eg burnt spots).
Most of the time the problem is CCU. Trick to repair it include testing and eventually reheating the solder joint of the two on-board relays, cleaning connector contacts with circuit cleaner solution. This in case that the problem is CCU.
Disconnect the unit from power for five minutes as first test. This will reset CCU.
Nov 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet with a code F 11. I replaced the CCU, do you think its the Motor Control Board or is it time to recycle?
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). As you have already replaced the CCU then to start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
361 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
