Question about Car Audio & Video
Mitsubishi warrior cd changer error code E-01
My Mitsubishi warrior cd changer comes up with E-01. The radio still works and power is still getting to the changer. Any ideas?
SOURCE: monsoon Radio CD CHANGER ERROR
I'm having the same problem and want to know how to fix it without having to take it to the dealer. my cd's won't come out or let me put any in and it keeps saying CD CHANGER ERROR
Posted on Dec 21, 2008
SOURCE: Cd player in a 2002 acura tl
stuck CD in 6 disk player
Posted on Dec 27, 2008
  • 4 Answers
SOURCE: Jeep RDS CD Problem
Did you change the battery ? If so try disonnecting and reconnecting the CD changer.
Posted on Dec 28, 2008
SOURCE: RADIO CD problem
I found a solution on youtube...NatiGame.com
Posted on Jan 12, 2009
SOURCE: 2001 Acura 3.2CL Problem BOSE System (CD changer)
You can disconnect the battery, reconnect it and use your radio code to get it working again. This worked for it...it's like I 'rebooted' the cd player.
Posted on Apr 12, 2009
I get E-01 error of my cd changer
The fault is actually inside the CD changer, when one disc is selected the changer moves the gearing inside to slot from one CD to the other.
While this operation is happening the selection arm jams !!
Then giving an error at the radio display..
To fix the problem, disconnect the CD changer from the trunk of the car,
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again,
grease the moving parts with light lubricant
Good Luck
Feb 24, 2011 | Mercedes-Benz C-Class Cars & Trucks
I have a 2003 Audi A6..the cd player does not work...it shows "ERROR" 3..and the light does not come on when you push the cd button. What could be the problem?
It sounds like a cd is jammed in your player. If you have the radio code, you can try pulling the fuse for the radio and then leaving it out for 15 minutes and putting it back in. Then put your radio code in. Sometimes it will reboot your player and kick the cd out, sometimes not. If it wont, you would have to get it serviced by a professional to get the cd pulled out or replace the unit. Do you have a cd changer or a bose sound system in your audi?
Sep 23, 2010 | Car Audio & Video
I have an 01 town and country and the radio doesnt work bu the clock works and cd shuttle gets power
I had the same problem after I changed the battery. No radio but power to the CD changer for a month. I finally went back and took the terminals off and cleaned them REALLY good. Works again!
Mar 11, 2010 | 2001 Chrysler Town & Country
Renault Megane CD changer CD CODE required
i need code for megane II
vehicle code: VF1BM0G0628080003
Feb 06, 2010 | Car Audio & Video
Hello - My 2001 VW New Beetle Monsoon radio reads "No Changer". What can I do to fix it?
If it's saying "No Changer" then it's possible that one of the connections between the radio and the changer itself has become disconnected, a possible blown fuse or worse still the changer itself has failed.
First of all check the fuse box, make sure there are not any blown fuses there and if you have to refer to your VW manual if you got the CD multi-changer with the car.
Locate the changer itself and check that any leads has not become disconnected and check behind the radio itself to make sure nothing has become disconnected.
Once you have checked all connections on the radio and changer, and checked the fuses, and you are happy that all seems well then you can try your changer again.
Don't forget to replace any blown fuses you find!!!
If you need anymore help or the changer still is not picked up by the radio please post back.
Good luck.
Aug 03, 2009 | USA Spec SCD-VW44 6-Disc CD Changer
ERROR 01
did all the disk you insert was not reading to device.. and got the same error code..?
Aug 08, 2008 | Alpine CHA-1214 12-Disc CD Changer
Getting E-1 error message for radio
Well I had a 1990 Xj6 with an aftermarket cd-changer in the trunk and it didn't work, so when I took it to an audio specialist he said that it needed to be replaced. But what he did say is that most manufactures use the same connection cables for their products, ex. Sony plugs will work on all Sony cd-changers. I now have a 1994 Jaguar XJ6 and I have the same error code. I know that Jaguar installed Alpine CHM-S620 cd-changers. So in theroy you could go to an audio store and get the same cd-changer and it should have the same plugs so you wont need to rewire anything. I havent done it yet because I just bought the 1994.
May 30, 2008 | 1994 Jaguar XJ6
Feb 29, 2008 | Car Audio & Video
Cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
Jan 14, 2007 | Kenwood KDC-3027A CD Player
Car Audio & Video Logo
527 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
