Question about HP LaserJet P3005n Printer
Having problems with tray 1 picking up paper first. I need it to pickup from tray two first?
  • 81 Answers
Print off the menu map from the control panel. This will give you an idea of the menu structure. Check if Manual Feed is switched off within the Printing menu.
Posted on Oct 13, 2009
2 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: Paper pickup in tray 2 not working
This is an issue i've seen many times.
The gear that drives the lower tray barely conacts the gear in the main body.
You cannot buy just the gears, you will have to buy a new option cassette assembly.
If you lift the printer off of the lower cassette you'll see the suspect gears.
Posted on Dec 20, 2008
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
The samsung ml 2250 printer doesnt pick up the paper out of the paper cassette. It works someteiimes but mainly the paper is not picked up at all and you hear the noise like it wants to pick it up but cant...
Hi there,Don't think its the clutch. I would rather say its more a problem of the paper not getting pushed up against the pickup rollers so you could try stretching the spring a bit and see if it helps.. What you also could try is removing the tray and bypass the paper sensor and see if when you print the pickup roller does turn.
Regards
Jul 28, 2011 | Samsung (ML2250S3XAA) Paper Cassette for...
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Am having paperjams when picking papers from tray 4
I guess that your printer need to replace its tray 4 pickup rolls, how many paper did your printer print....Did you replace the maintenance kit before???
contact me at walid_sayed@hotmail.com
Mar 19, 2010 | HP LaserJet M9050 MFP Printer
Dec 19, 2008 | HP LaserJet P2015dn Printer
Will not print. says out of paper but there is paper in the tray.
this is indicate that the roller is having some kind of problem.
open the backdoor, make sure there is nothing preventing the roller (should be 3) do its job.
take out the paper from the paper tray. make sure there nothing in the way of center roller path.
re position the paper. load enough paper, so that the paper is right under neath the center roller, remove 2 sheet. try to print. if it pickup the paper, then it is telling you that the roller need to be replaced. if it still having problem pickup the paper. then there is something else we need to investigate.
Hp always being having problem with their printer roller since day one. over time the roller become smooth, and not able to pick up paper.
if the porblem presist, please repost it in this thread. so I can help you to solve the problem.
Nov 13, 2008 | HP PSC 1315 All-In-One InkJet Printer
No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
Pixma iP4200
These problems cane be caused by a number of things.
1. Dirty or worn pickup rollers. Clean the rollers with alcohol. This can be hard to do because you have to clean the portion of the roller that actually contacts the paper. This will only work if the rollers are slipping on the paper.
2. Object stuck in paper path. Again, can be hard to get rid of depending on how far in it is. It can actually prevent the tray from moving into the pickup position.
3. Broken gear in the paper pickup assembly, or somehow the timing has been changed. The gears in many paper pickup assemblies (or ASF for Auto Sheet Feeder) have to be timed correctly. If someone has pulled a piece of paper out causing the gears to skip a few coggs, the timing can be off and the unit will either not pick up paper or will fire a sheet or two out as soon as it's turned on. Unfortunately this fault would have to be corrected by a service tech who knows how to reset the timing correctly.
Nov 12, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Kyocera FS-1920 won't pick up paper from tray
replace pick up rollers and paper tray roller. Take out paper tray and toner, lift printer so you can see underneath you should see a set of rollers its nopt to hard to get out. also in the paper tray there is a roller swop that out to
Dec 14, 2006 | Kyocera Mita FS-1920 Laser Printer
HP LaserJet P3005n Printer Logo
208 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
