Question about Panasonic KX-P1131 Matrix Printer
Alarm on No answer.
Hello, we use this printer as a record for requested wake up calls at our hotel. the printer is programmed inconjunction with a pbx, on our old printer when the wakeup call is executed and the guest would not answer the printer would beep. by doing this it would alert the operators to try manually until the guest would wake up. does this printer have this alarm function?
I called panasonic,
Thanks
Posted on Oct 07, 2009
How do I turn off the alarm on the model #7-4837D
To silence the alarm momentarily
Press SNOOZE. The alarm will sound again when the snooze period is over.
To stop the alarm
Press ON/OFF. Then, the alarm will be on the following day at the same time.
To disable the alarm permanently
1. Press CANCEL button
2. The WAKE indicator will be flashing.
3. Press WAKE MODE button within 3 seconds
to deactivate the alarm function permanently.
http://manualzz.com/doc/2137875/ge-7-4837-clock-radio
Feb 07, 2018 | The Audio Players & Recorders
What is the alarm button for?
Waking you up ... Make and model may help you get an answer.
Nov 21, 2017 | The Audio Players & Recorders
PHONE CALLING 911, i CANT DISENGAGE!
To read a 911 Emergency Call alarm message:
1.Press Function
2.Press [ALARM]
3.Press [SHOW 911]
This will show what extension calls the 911.
4.Record the number of the extension from which the 911 call originated.
If additional 911 calls were made, press [MORE] to view them.
To delete the 911 alarm, press [CLEAR]
5.Contact the appropriate emergency services.
6.Press [EXIT].
Apr 20, 2014 | Mitel Superconsole 1000
How do I set the alarm so it will activate on weekdays. It only works for Saturday and Sunday. Thanks
Hello
Sure Alarm battery Back-Up System
This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
wake you up even if the power is 'Off'at the selected wake up time. If your power
is 'Off'at the selected wake up time the clock display will be off and the radio will
not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
even if you had selected the "Wake to Radio"option.
The Sure Alarm will sound for 30 seconds and then shut off automatically.
To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
Pressing the SNOOZE button has no effect during Sure Alarm operation.
Note: In order to maximize the life of the built in lithium battery, please be sure
to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
will be disconnected from the AC outlet for more than a few hours. This will
prevent the Sure Alarm from turning 'On'unnecessarily.
1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
The display will change from the correct time
to the Alarm 1 or Alarm 2 wake up time.
2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
SET + or - button to move the display ahead or back to your desired wake up
time.
3.) When the desired wake up time appears on the display, release the SET + or
- buttons.
Note: Be sure that you have set the wake up time correctly by observing
the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
AM indicator is 'Off', the wake up time is "PM".
4.) When the desired wake up time (AM or PM) appears on the display, release
the ALARM 1 or ALARM 2 setting buttons
Apr 20, 2011 | Emerson Smartset Clock Radio
How to program a wake up call for hotels room?
If I remember correctly, you can't do it from a 7630 phone. It requires a phone set up as a hotel operator to do it remotely. If your system is installed properly, you already have an operator phone, it's the one with the DSS console and it sets room status/ Check-In/Check-Out.
We have 7636's set up to do it and the command is *76*1 ext HHMM 0/1 0/1 . Now, the explanation HHMM is the time in 12 hour format if you are using a 12 hour clock, the first 0/1 is AM/PM for the 12 hour format, and the second 0/1 is ONCE/DAILY.
For the guest, the format is the same, but the code is *7601 HHMM 0/1 0/1 It's called Timed Reminder.
Carl
Apr 14, 2011 | Panasonic KX-T7630 Corded Phone
Hi, I was wondering if my LG DVD Micro HiFi System FB163, could play an the radio as an alarm? If so how?
Hello, To set a radio station as your alarm -
  1. Press and hold "timer" for two seconds.
  2. All the functions DVD/CD/USB/Tuner will flash for two seconds.
  3. Press "set" when the mode you want to be woke up by is showing.
  4. If you pick "tuner" then "play" and "record" will flash alternately flash in the display.
  5. Pick one by pressing the "set" button.
  6. Then select the preset station you want to wake up to.
  7. Now press set again.
  8. You will now wake up at the time and radio station you selected.
Regards, Tony
Mar 24, 2011 | LG FB163 DVD/DivX USB Micro system Shelf...
Remote access, panasonic cordless phone and answering machine
I phoned in from another phone and retrieved my messages. The problem was not with the answering machine but with the phone and calling card I had been using. Don't use a hotel switch board nor calling card, too many intermediate parties for the 2 digit code to work with.
Aug 18, 2008 | Lands Phones
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Panasonic KX-P1131 Matrix Printer Logo
53 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
