Question about Old Town Cayuga Recreational Kayak -
I damaged the tip of the bow with a snowblower and there is a 2 or 3 inch opening that needs patched.
    Problem Solver:
  • 15 Answers
Use a fiberglass repair kit available at most hardware stores. Use an overlay prior to patching if the hole is bigger than a quarter so you don't develop a soft spot in the hull.
Posted on Aug 15, 2010
Draw length adjustment on an old browning explorer 2 compound bow serial number y1b 3995
hard question lots of explorer 1 s
just pulleys and bow string
explorer two same system
if a 1960s bow 47 inch tall 55- 70 pounds approx
Sep 17, 2016 | Optics
Only runs for a short time
Jeff, Try running with cap off for a short time to see if cap vents plugged, probable dirty carburetor.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Snowblower Starts Then Stalls
Tecumseh Carb snowblower cleaning 1 of 2
HOW TO Remove Clean Fixed JET on Snowblower Carburetor
Mar 23, 2016 | Toro 1028OXE Power Max 38663 2-stage...
Does 4-stroke and 4-cycle mean the same thing?
yes ... intake, compression, power, exhaust .... vs 2 cycle which mixes them down to two.
Mar 30, 2015 | MTD PRODUCTS INC Craftsman 21" 179cc*...
How can above ground pool be repaired
It sounds like the hole is relatively small. You can make a patch using a piece of sheet metal or a piece of flat aluminum which you can purchase at Lowes or Home Depot in the hardware dept. Use sheet metal if the metal surround is metal. Use aluminum if the surround is aluminum. You can tell which is which by taking a magnet and touching the metal. If the magnet sticks, it's metal not aluminum. Cut the patch using sheet metal shears to a size that is 4 inches by four inches larger than the hole. Then you'll have two inches on each side of the hole. You are going to need to put the patch on the inside of the metal, between the liner and the metal surround. This so the hole edges won't tear the liner. When you cut the patch, round off the edges so there are no sharp edges. Take duct tape and cover the edges of the patch. Place 1/2 the width of the duct tape and apply it to one side of the patch and fold the other half over to the other side. You can cut a round patch, but a square or rectangle patch will be easier. Just cut the corners round. Purchase a small tube of silicone sealant ( when you but the patch material) and apply a bead around the patch edges and in the middle. Then affix the patch over the hole. Wipe off any sealant that ozzed through the patch so it doesn't bond to the liner.
Jun 01, 2014 | Karcher 2500 PSI Pressure Washer
What's a typical arrow made of?
An arrow consists of a shaft with an arrowhead at the tip of the shaft. Arrow sizes vary from one another ranging from 18 inches to 5 feet, the flight velocity of arrows generally ranges from 100 to 300 km/h, depending on the bow power, and the condition of weather and wind.
Jul 30, 2012 | Archery
What's a common string made of?
An ideal string material is strong for its mass, resists stretching, and remains strong after exposure to moisture. Bow strings are frequently made of animal byproducts such as sinew, intestine, or hair. Plant fibers such as linen were also common and usually had a superior ratio of strength to mass.
What's the best bow for beginners?
You can findlots quality bows in different prices, but the best bow I advise you to get,the bow I actually purchased myself, is the Parker Sidekick. This bow isdesigned for beginner archers as it comes in 18- to 28-inches of draw lengthadjustable at 0.5 inch increments. Draw weights are available from 20- to40-pounds and 40- to 60-pounds with a comfortable 80 percent let-off.
Small rip in treadmill belt
No really. You need to replace the entire walking belt. Not to hard of a job and most replacement belts come with some instructions. We use www.treadmillpartszone.com for parts.
Apr 10, 2009 | NordicTrack E4000 Treadmill
Ariens 2 cycle snowblower runs a short time then stalls.
That sounds like a float problem. When you tip it back it is raising the floats letting the fuel go through the carb. But when back at normal it closes the the fuel feed and thus stalling the engine check the float assembly.
Jan 22, 2009 | 2002 Husqvarna TE 400
Old Town Cayuga Recreational Kayak -  Logo
130 people viewed this question
Top Old Town Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Old Town Boating Expert? Answer questions, earn points and help others
