Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Samsung 52" HDTV red convergence bowed
I replaced both stk chips and the convergence is still bowed. I have some electrical engineering experience so I am not scared to fix. I just have no idea where to begin. In convergence mode, the red will not even move. Blue will move but is way off. I have 6 convergence areas. Three on top, three in middle and three at bottom. I am in the process of going through the resistors now to make sure they are not bad. Does anyone have a schematic of the convergence board or some insight into a systematic process to figure out the problem?
Thanks,
Russ
  • 1 more comment
  • rieske Oct 06, 2009
    Using an ohm meter, how do I tell if they are bad?
    okay, I turn my meter on touch both sides of the resistor. If I hear a beep it is good, if I do not, it is bad? Where do you place the red and black prongs? I have done it under the board on the soldered ends and on top on both sides of the resistor... I am not sure if I even have my meter set to the right setting...
    I have done it on ac voltage, ohms, and tone...
    which do I use...
    Russ
    I sent the board with a friend who was going to take it to an avionics tech at Delta. He was going to look at the board and check all the components. I will let you know how it goes. I replaced the STK but not they were only 6.50 each. Do you think they will work or should I get the OEM from Samsung? I guess if this does not work, I will buy the whole board.
    Thanks again!
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
First---look close at all the resistors around the chips--any that are white or discolored in the middle are suspect--MOST of the time a low value resistor (1.5, 1.8, 2.2 ohm) will be bad---check them all--there will be some 150 ohm or higher--they usually do not go--
There is a site I have found where you can download a service manual---I offer it only as information and not a solution-----http://www.nodevice.com/
If you find an open resistor or resistors they all have a location number on the top of the circuit board in case they are burnt and you cannot tell value from the color bands marked on them.
LET ME KNOW IF YOU HAVE ANY QUESTIONS OR NEED ADVICE- I am here to help people.
Regards, SD TECH
Posted on Oct 06, 2009
Testimonial: "thanks! I was able to understand and follow your instruction! Russ"
  • 1 more comment
  • SD Tech
    SD Tech Oct 06, 2009
    other than ones that are discolored--look for one or more with no reading across it---have the meter set high enough so the 150 or higher resistors read---an open resistor will not have any reading--like a open fuse--you are looking for one or more open--gone.
    Most of the resistors around the chips will have RK location numbers like RK44 etc---if they are all good--double check your soldering to make sure you did not miss any when you soldered them in.
    SD Tech
  • SD Tech
    use the ohms setting and look to see what each one reads---a 1.5 can read a little higher in circuit---best way(does not matter which lead goes where) is on top of board so you can look at the resistors to see if any are discolored in the middle---white discoloration means probably bad.
  • SD Tech
    SD Tech Oct 07, 2009
    All of the STK chips were designed by Sanyo--the generic ones are fine--I buy and use ones from Ebay and of about 300 I have bought in the last 2 years only got two new ones that were bad--I had a friend who had a Mitsubishi---the chips from them were 25 dollars each--we looked at the Mitsubishi chips and guess what? They had the exact same production number in the upper right corner as my generic ones--lots of these places buy generic and resell at much higher prices saying it is OEM---other than 2 out of 300 being bad that I bought--none of these customers has ever called me to say they have the same problem again---
    Good luck and let me know what happens--you are better to repair the board then replace it--I have seen people replace the board and have new troubles.....be careful.
    Also--IF I CAN HELP YOU IN ANY WAY--do not hesitate to ask.
    SD TECH
I need a convergence kit for a rca 52 inch rear projection tv
what type of problem with convergence? no convergence at all? pitcure bowing? this in the setup menu do you have the convergence option? a convergence ki in a standad porojection has stk ic/s this model does not .you might have the fl231 fuse problem.. generally its board replacement. then the problem becomes alighnment.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red convergence looks like its curling in the coner like on either end it bows up ~------~
The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 23, 2010 | RCA HD52W56 52" Rear Projection HDTV
Toshiba 65hdx82 convergence issues
check fuse resistors near STK, and broken PCB around digital convergence board (board in a metal box verticaly mount beside STK.
Apr 23, 2010 | Toshiba 65HDX82 65" Rear Projection...
Convergence off screen looks bowed
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 21, 2009 | RCA R52WM24 52" HDTV Projection Television
The tv has shadow of red and green about 10 inches in on both left and Right sides. Center is still ok?
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 20, 2009 | Zenith D52WLCD 52" Rear Projection...
SAMSUNG HC-P4752W 47" TV Convergence problem
Resistors most likey...look for burnt or discolored resistors near the convergence chips.
Apr 07, 2009 | Samsung HC-P4752W 47" Rear Projection...
Red Convergence Bowing
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 02, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
I have a convergence problem. My Sony KP-65WS510 has a picture that looks like 3-D and bows at the bottom and top of the screen. I already replaced both the IC's STK 392-560 (2 qty.) and check all six 3.5a...
Screen looks 3D
>>>Solution<<<<
Dec 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Tv troubleshoot for me
chances are that IC804 has failed. You have two ICs that allow you to converge the three colors. IC804 is used for Red Horizontal and Vertical Convergence and also for Green Vertical Convergence. IC805 is used for Blue Horizontal and Vertical Convergence and also for Green Horizontal Convergence. These ICs run very hot and have a very high failure rate which sometimes will cause damage to resistors in their associated circuits. They are both STK-110 and it's best to replace them both at the same time. It's also a good idea to upgrade them to either STK-150 or STK-180. These will run a lot cooler than the STK-110.
Before replacement do inspect for any open or overheated resistors as I stated earlier. Being you only have problems with Red Convergence the plus and minus power supplies should be okay since they are common to both ICs.
Try www.tritronicsinc.com. They have the Hitachi CZ00433 (STK392-150) in stock for $20.11 ($32.43 retail). These are Hitachi OEMs. I've had very good results replacing STK392-110s with these chips. Do check for open or overheated resistors before replacing these chips
Dec 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
175 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
